Print results with Prime.
01-09-2015, 09:28 AM
I have some programs that return many results. I have to note them by hand on paper, one after one.
Is it exist a system to print directly from prime, like for exemple with HP 41 and his
printer ?
Thanks for help. Gérard.
Gérard.
06-02-2016, 08:03 PM
RE: Print results with Prime.
I just happened to see this old question with no answers...
If anyone still wishes to do this:
I don't know of any support for printing direct from the calculator.
But the following work-around is better than using pen and paper:
Instead of using PRINT(this), use
Notes(filename):=Notes(filename)+this //append results to file
Then after the program finishes, your results can be cut-and-pasted from the Notes file to your PC/Android and then printed.
Stephen Lewkowicz (G1CMZ)
ANDROID HP PRIME APP NO LONGER WORKS OFFLINE?
06-04-2016, 06:36 AM
Many thanks Stephen, this run pretty well !
Good day !
Gérard.
06-04-2016, 04:58 PM
I enjoyed that. Someone would have a ready program that demonstrates this function?
Leo
06-04-2016, 10:07 PM
(06-04-2016 04:58 PM)jrozsas Wrote:  I enjoyed that. Someone would have a ready program that demonstrates this function?
This demonstrates the technique - it works for the text and numbers, I haven't tried other data types.
 LOCAL G1CMZ_PRINTER:="G1CMZ_PRINTER_DEMO";
 LOCAL OKC,CHS,II;
 LOCAL NL:=CHAR(10);
 PRINTER (TXT)
  Notes(G1CMZ_PRINTER):=Notes(G1CMZ_PRINTER)+TXT+NL;
 EXPORT DEMOPRINTER()
  OKC:=CHOOSE(CHS,"DEMO","RUN DEMO");
  IF OKC THEN
   IF CHS==1 THEN
    Notes(G1CMZ_PRINTER):="Printer reset at "+Time+NL;//ERASES OLD DATA
    PRINTER("This file has too much data");
    PRINTER("only if you have no pen");
    FOR II FROM 1 TO 9 DO
     PRINTER(II);
    PRINTER("ON PC:SELECT FILE AND PRINT");
    PRINTER("ON ANDROID:COPY CONTENTS TO CLIPBOARD AND PASTE");
  MSGBOX("RESULT IN Notes("+G1CMZ_PRINTER+")");
06-06-2016, 09:10 AM
Thanks StephenG1CMZ !
Leo
