Slope() appears broken.
12-17-2014, 01:53 AM
Hi, I calculated slope(x^2-5,2) and got a 0. But in the Manuel the answer is 4.
I tried it in both "Home" and "CAS" mode with both Degree and Radian. but still got a 0 as the result. Is there a way to fix it?
I have the version 2014.1203.6975.
12-17-2014, 02:17 AM
RE: Slope() appears broken.
The commands slope() and SLOPE() are different. I believe the one you are looking for is SLOPE().
Graph 3D | QPI | SolveSys
12-17-2014, 02:18 AM
Hi!
I can't find SLOPE in catalog but slope exist. In Home, SLOPE exist if you enter it letter by letter.
In Home, SLOPE(3-x^2,5) ... -10
Bizarre thing that SLOPE don't show in catalog...
Marcel
12-17-2014, 02:40 AM
Sorry!
I find it in the app function catalog.
Marcel
12-17-2014, 03:46 AM (This post was last modified: 12-17-2014 04:22 AM by mpowell@rogershsa.com.)
Ok, Cool, Got it. But only X, with x it shows a 0.
12-17-2014, 04:20 AM
(12-17-2014 03:46 AM)mpowell@rogershsa.com Wrote:  Ok, On the Virtual HP Prime it shows a 10, but on the regular HP Prime calculator it shows a 0..
Did you make sure that you typed SLOPE in all caps?
12-17-2014, 04:27 AM
Yes. I must of used x instead of X.
12-17-2014, 02:16 PM
It seems that SLOPE should be added to the catalog.
12-17-2014, 02:57 PM (This post was last modified: 12-17-2014 03:01 PM by Tim Wessman.)
(12-17-2014 02:16 PM)Helge Gabert Wrote:  It seems that SLOPE should be added to the catalog.
It is an application function. tool->app->function->SLOPE. At the moment, these do not appear in the catalog with the system wide commands.
However, I agree that there needs to be a way to incorporate these a bit better into the catalog as they can be harder to locate. The basic issue is that they are not global functions and often are duplicated with multiple apps. For example, SLOPE will appear in every function app, CHECK in every graphing app, etc. I've got a few ideas there though and think we can make it work nicely at some point.
TW
12-17-2014, 04:34 PM
Sounds good to me. Thanks!
