Spreadsheet Cell Color
11-27-2014, 01:55 AM
I've read the manual and is possible formatting the Cells in Spreadsheet, changing the color. Is it possible changing it programmatically?
Thank you very much for your help
Rogerio
11-29-2014, 12:15 PM (This post was last modified: 11-29-2014 12:16 PM by Tyann.)
RE: Spreadsheet Cell Color
(11-27-2014 01:55 AM)rbiondi Wrote:  I've read the manual and is possible formatting the Cells in Spreadsheet, changing the color. Is it possible changing it programmatically?
Rogerio
hello
yes with cell (row, column, 6) := n for text and cell (row, column, 7):=n to the bottom
with 0 <= n < = 32768 .
11-29-2014, 02:27 PM
Note that I would recommend using the RGB function for setting your color. That way it will be compatible when/if color depth changes for future revisions/software versions.
TW
11-29-2014, 04:23 PM
(11-29-2014 02:27 PM)Tim Wessman Wrote:  Note that I would recommend using the RGB function for setting your color. That way it will be compatible when/if color depth changes for future revisions/software versions.
Hello Tim
I thought RGB did not work, I have to repeat some tests , in fact it is necessary to limit the values ​​to not exceed 32768 .
RGB ( 0,0 to 127 ,0 to 255 ) .
From what I understand .
Sorry for my english : google translation.
Note that you can use the syntax: A6 (6) in place of cell ( 6,1,6 ) for example.
11-29-2014, 10:35 PM
Hmm. Indeed. I think that needs to be fixed.
TW
11-30-2014, 11:47 AM
Thank you very much for the help!
I'm still learning more about the calculator and loving it so much!
Best regards,
Rogerio
