(42S) Hill's Encryption System
11-24-2014, 07:39 PM
(This post was last modified: 06-15-2017 01:48 PM by Gene.)
Hill’s ciphering algorithm can be accomplished on the HP 42S using the following programmes.
To use: 1. Actuate programme HILL to set parameters. 2. ENCY encodes the alpha register, returning the coded message to the alpha register. 3. DECY decodes the alpha register, returning the clear message to the alpha register. 0. { 33-Byte Prgm } 1. LBL “R10” 2. RAN 3. SF 25 4. RCL “RMAX” 5. FC?C 25 6. 10 7. * 8. IP 9. RAN 10. 0.5 11. – 12. SIGN 13. * 14. END Produces one random integer element of the ciphering matrices. 0. { 43-Byte Prgm } 1. LBL “LTRI” 2. ENTER 3. NEWMAT 4. EDIT 5. LBL 00 6. RCLIJ 7. X=Y? 8. GTO 01 9. XEQ “R10” 10. → 11. GTO 00 12. LBL 01 13. SIGN 14. STOEL 15. STOIJ 16. I+ 17. FC? 76 18. GTO 00 19. CLX 20. EXITALL 21. END Forms a lower triangular square matrix for integer input Eg 3 LTRI returns a 3*3 LT matrix. 0. { 22-Byte Prgm } 1. LBL “MMOD” 2. EDIT 3. LBL 00 4. RCL ST Y 5. MOD 6. → 7. FC? 77 8. GTO 00 9. EXITALL 10. END Makes the matrix in X-register modulo the integer in the Y-register Eg 7 matrix MMOD returns the matrix modulo 7. 0. { 34-Byte Prgm } 1. LBL “A→M” 2. ALENG 3. RCL/ ST Y 4. ENTER 5. FP 6. X>0? 7. SIGN 8. + 9. X<>Y 10. NEWMAT 11. EDIT 12. LBL 00 13. R↓ 14. ATOX 15. → 16. FC? 77 17. GTO 00 18. EXITALL 19. END Converts the alpha-register contents to a matrix of integers of column dimension the X-reister Eg 3 A→M returns a 3-coumn matrix. 0. { 95-Byte Prgm } 1. LBL “HILL” 2. INPUT “RMAX” 3. INPUT “SHIFT” 4. INPUT “CYMOD” 5. INPUT “MSIZE” 6. XEQ “LTRI” 7. ENTER 8. ENTER 9. TRANS 10. * 11. RCL “CYMOD” 12. X<>Y 13. XEQ “MMOD” 14. STO “INMAT” 15. R↓ 16. X<>Y 17. FIX 00 18. INVRT 19. RND 20. ALL 21. ENTER 22. TRANS 23. X<>Y 24. * 25. XEQ “MMOD” 26. STO “OUTMAT” 27. END Asks for the coding parameters. Eg For capitals in to capitals out: Alpha to alpha: SHIFT 65 CYMOD 26 For any character in to any character out: All to all: SHIFT 0 CYMOD 256 0. { 85-Byte Prgm } 1. LBL “ENCY” 2. RCL “INMAT” 3. GTO 00 4. LBL “DECY” 5. RCL “OUTMAT” 6. LBL 00 7. ENTER 8. DIM? 9. X<>Y 10. R↓ 11. XEQ “A→M” 12. X<>Y 13. * 14. RCL+ “SHIFT” 15. RCL “CYMOD” 16. X<>Y 17. XEQ “MMOD” 18. RCL+ “SHIFT” 19. LBL “M→A” 20. CLA 21. XTOA 22. AVIEW 23. END ENCY encodes the alpha-register & DECY decodes the alpha-register. |
