Calculated Confidence Intervals
04-27-2023, 02:23 PM
How does one do a z or test/confidence interval without the standard deviation? (given only the mean/proportion and sample size)
This can be done on other calculators, like the TI-84, and I wonder how it can be done here.
Thanks.
05-08-2023, 07:17 AM
RE: Calculated Confidence Intervals
I believe you can use the Inference app for this.
Method: confidence interval
Type: Z-Int: 1 π
Press [num]
x - success count (if given proportion of successes, p*n approx = x)
n - sample size
C - confidence level
Then press the Calc key on screen. Lower/Upper is the CI.
Alternatively you can use the command ConfZ1prop(SuccCount, SampSize, ConfLevel), which returns a list of 4 values: {Lower critical value, lower bound, upper bound, calculated proportion}.
- neek
