Quick switch between number format and exact/approximate results
10-16-2022, 02:57 PM
When I'm using a CASIO calculator, there is a extremely useful feature. That is we go to the history, select a output, and press the exponential key, we can toggle between scientific notation of the number or the number format. This can make small numbers much more readable, so that I don't need to count the zeros if I have a number like 1e-5. The fraction key also works similarly by switching between exact forms and approximate results.
Is there anyway to implement this, such as by user keyboard? Although less ideal, the toggled output can be shown else where, if changing directly the display in the history is not possible.
10-17-2022, 10:12 PM
RE: Quick switch between number format and exact/approximate results
which Casio model are you using.
10-18-2022, 01:37 AM
Something like this ?
PHP Code:
// 2022.1016 pretty-prime v0.2b
#pragma mode(separator(.,;) integer(h32))
LOCAL fs;
KEY KS_Eex()                                // assigned to <<shift>> <<EEX>>
IF HFormat≠0 THEN
    fs
:=HFormat;                            // save orig setting
HFormat:=0;                             // show standard format
ELSE
    IF
fs≠0 THEN
      HFormat
:=fs;                          // show alt.format
ELSE
HFormat:=1;                           // force alternate view
  RETURN -
1;
END
10-18-2022, 10:48 AM
(10-17-2022 10:12 PM)thenozone Wrote:  which Casio model are you using.
Most modern Casios, fx-991ES for example.
