HP Prime V1 rebooting/crashing loop
09-21-2022, 06:16 AM (This post was last modified: 09-21-2022 02:34 PM by Vizavucha.)
Hi all, I recently found my HP and when I went to try use it. It doesn’t get past the startup and just stuck in a reboot loop. I’ve added a video to show an example. Any help is appreciated. Thank you! https://youtube.com/shorts/CuzP88HRxbc?feature=share
-Nate
09-21-2022, 01:40 PM (This post was last modified: 09-21-2022 01:58 PM by muteki.)
RE: HP Prime V1 rebooting/crashing loop
You could try holding SYMB key while pressing ON (or the RESET button on the back) to enter DFU mode. If that works, connect the calculator to PC, download the latest firmware and flash it. If there's a firmware corruption this should resolve it.
09-22-2022, 01:47 AM
Hello, looks like that did the trick. It's up and running again after new firmware. Thanks!
