Emu48 not reading HP50g KML files
05-09-2022, 02:17 PM (This post was last modified: 05-09-2022 05:09 PM by acser.)
EM48 does not know how to interpret old style KML files.
Anything I am missing here?
Emu48 v1.48 and v1.62+ worked fine, Emu48 v1.64 (with or without the patch) does not work.
Follow the below steps to reproduce:
1. Download https://hp.giesselink.com/Emu48/Emu48v164Setup.zip from https://hp.giesselink.com/emu48.htm
2. Download the patch from https://hp.giesselink.com/Emu48/E48BP64.ZIP copy the files to the Emu48 install directory.
3. Get the HP 50g skin from https://www.hpcalc.org/details/6569, copy the files to the Emu48 install directory.
4. Get the EMUROM from https://www.hpcalc.org/details/6744
5. Modify the HP 50g.KML file in the Emu install directory to the ROM.49G file name
6. Start Emu48. It will not show the option for Grokwik's Real 50g
Would it be possible to package Emu48 in a way that it is usable with 50g ROMs and KML files out of the box?
Thanks,
A
10-12-2022, 09:59 PM
RE: Emu48 not reading HP50g KML files
Same behavior here....
do you find any solution?
10-13-2022, 02:20 AM
You would need to put the Emu48+ 1.64 executable in the folder instead to use the 50g KML file:
https://www.hpcalc.org/details/6523
