Converting Polar and Rectangular
05-05-2022, 05:05 AM
I’m having trouble downloading a certain program for my hp prime. Every time I type in the programs below I get a syntax error. Is there anyone that has a link where I can download these programs rather than manually put them in?
P_to_R(r,a):=
return (r*COS(a)+r*SIN(a)*i);
R_to_P(x,y):=
return (CAS(collect(ABS(x+y*i)))+"∡"+CAS(collect(ARG(x+y*i))));
05-05-2022, 02:30 PM
RE: Converting Polar and Rectangular
Should the programs not start with
EXPORT P_2_R(x,y)
Or something instead of your first lines?
If you try it on a calculator, it will tell you where the problem is, by clicking Info after running the program, or clicking Check, when in writing the program.
05-05-2022, 04:07 PM (This post was last modified: 05-05-2022 04:20 PM by Didier Lachieze.)
These are CAS programs, you need to add #cas and #end statements:
#cas
P_to_R(r,a):=
R_to_P(x,y):=
#end
Btw, you can use instead of these programs the built-in functions rectangular_coordinates() and polar_coordinates() as explained here.
