Toolbox Shortcuts
06-21-2021, 10:15 PM (This post was last modified: 06-21-2021 10:16 PM by matalog.)
Toolbox Shortcuts
Is there a way, when you press the Toolbox button, to ensure that you are in the Math menu, by pressing a button?
For example, I want button X that will allow me to press 'Toolbox',X,5,2 which will result in the COMB() function being called?
The thing is, that when I press the Toolbox button, the last menu that I have accessed within it, is the one that is initially active. Therefore I have to press Toolbox, then use the touchscreen to activate the Math menu, then press 5 and then 2 to access the COMB() function.
