Persistent custom menu for DM42
03-20-2021, 01:52 PM
(This post was last modified: 04-07-2021 10:47 PM by ljubo.)
I have slightly changed Free42 code to make the custom menu the system base menu. For DM42 that behavior makes sense as DM42 has dedicated custom keys - for me this change greatly increases usability of the DM42. The new behavior:
Attached is the zip file with the source code patch and precompiled new firmware. As usual, use it at your own risk, see LICENSE and COPYING files ![]() @Thomas - would be great to know if there is a more elegant way to get the same behavior. Actually, in my opinion, Free42 itself would benefit from dedicated custom menu keys (I know it can be "skinned", but I mean as the default). Update 1: Fixed "SHOW" bug - new zip file DM42-3.17-2.5.20p2.zip attached. Update 2: Fixed an issue with briefly displaying garbage text when pressing EXIT. New zip file DM42-3.17-2.5.20p3.zip attached. Update 3: Switched to the new DM42 version 3.18 beta 1 (free42 v3.0.1 + bug fix in complexpool logic) Update 4: For latest version please visit https://github.com/ljubo106/DM42pcm Note: Firmwares below are neither provided by nor supported by SwissMicros! -Ljubo HP-15C, DM15L, HP-35S, DM42 |
03-21-2021, 03:26 PM
(This post was last modified: 03-21-2021 05:30 PM by ljubo.)
RE: Persistent custom menu for DM42
DM42-3.17-2.5.20pc has an ugly bug with "SHOW" function (freeze).
Please use DM42-3.17-2.5.20p3 instead. -Ljubo HP-15C, DM15L, HP-35S, DM42 |
03-29-2021, 10:43 AM
I like this extension and found it very useful. But I think there are some things to correct: - EXITALL does not return to CUSTOM menu - but the next key press will show the CUSTOM menu - PRGM mode: I've used the keys [up] / [down] to browse through the program - this is impossible with the CUSTOM menu. It is possible to switch to the System menu with [CUSTOM] and use so [up] / [down] for program browsing - perfect would be an configuration of this behavior On/Off persistant CUSTOM menu at all and On/Off CUSTOM menu while PRGM mode The persistent CUSTOM menu is very useful! Thanks! Fossy |
03-29-2021, 10:30 PM
(03-29-2021 10:43 AM)fossy Wrote: Hello,Thanks (03-29-2021 10:43 AM)fossy Wrote: But I think there are some things to correct: Good catch - will fix that (or declare it a feature ![]() (03-29-2021 10:43 AM)fossy Wrote: - PRGM mode: I've used the keys [up] / [down] to browse through the program - this is impossible with the CUSTOM menu. It is possible to switch to the System menu with [CUSTOM] and use so [up] / [down] for program browsing Actually that should work - if in PRGM mode "Exit" will exit custom menu. Have you tried that? (03-29-2021 10:43 AM)fossy Wrote: - perfect would be an configuration of this behavior On/Off persistant CUSTOM menu at all and On/Off CUSTOM menu while PRGM mode I was thinking about that - maybe in some of future versions. -Ljubo HP-15C, DM15L, HP-35S, DM42 |
