(10C) Newton's Method Solution to f(x) = 0
03-13-2021, 05:15 AM (This post was last modified: 03-14-2021 03:08 AM by Gamo.)
I don't see one here the Solution to f(x) = 0 program for the HP-10C
So I'm adapted this Newton's Method Solution to f(x) = 0 from the
HP-25 Applications Book and since the HP-25 only got 49 programming space so
it is possible to extended a bit more to work on the HP-10C or HP-12C as well.
Procedure:
Put f(x) equation at line 41 by start at [GTO] 40 and end with [GTO] 18
Set Precision to Register 2 : example [EEX] [CHS] 6 [STO] 2
[f] [PRGM]
Enter the nearest X (Your guess) to the root then press [R/S]
Root is save to Register 1
Program:
01 STO 1
02 CLx
03 STO 0
04 RCL 1
05 GTO 17
06 R↓
07 STO 4
08  1
09 STO 0
10 RCL 1
11 RCL 1
12 EEX
13  5
14  ÷
15 STO 3
16  +
17 GTO 41
18 X=0
19 GTO 39
20 RCL 0
21 X=0
22 GTO 06
23 R↓
24 RCL 4
25  ÷
26  1
27  -
28 1/x
29 RCL 3
30  x
31 STO-1
32  0
33 X<>Y
34 X≤Y
35 CHS
36 RCL 2
37 X≤Y
38 GTO 02
39 RCL 1
40 GTO 00
41 Start f(x)
42 .
43 .
44 .
45 .
> GTO 18
Example: X^X = 1000
I will store 1000 to Register 5
Enter Precision: [EEX] [CHS] 6 [STO] 2
Enter Equation: [GTO] 40 [P/R]
[LN] [LSTx] [x] [RCL] 5 [LN] [-] [GTO] 18 [P/R]
Run: [f] [PRGM]
Enter guess: 6 [R/S] ... about 30 second display 4.555536
To check answer: [RCL] 1 [RCL] 1 [Y^X] display 999.99997
Put to FIX 2: [f] [FIX] 2 dispaly 1,000.00
Remark:
Program Line Number 32 to 35 is the [ABS] function.
This [ABS] alogrithm only use the conditional test so it help on
the program running speed especially on a program that do iterations.
For more detail about this function here:
https://www.hpmuseum.org/forum/thread-12138.html
Gamo 3/2021
03-15-2021, 04:41 AM
RE: (10C) Newton's Method Solution to f(x) = 0
(03-13-2021 05:15 AM)Gamo Wrote:  I don't see one here the Solution to f(x) = 0 program for the HP-10C
Have you seen this ? Have a look at page 9 ... Smile
V.
03-16-2021, 01:26 AM
Valentin Albillo Thank You
I saw many of your articles they are all very interesting.
Your f(x)=0 solver program is shorter too really nice.
Gamo
03-16-2021, 02:46 AM
(03-16-2021 01:26 AM)Gamo Wrote:  Valentin Albillo Thank You
You're welcome. Thanks to you for your interest and kind words, much appreciated.
Regards.
V.
