PockEmul for IOS now available
03-06-2021, 11:33 AM (This post was last modified: 03-06-2021 01:50 PM by remy.)
Hi all,
I am very pleased to annonce the very first release of PockEmul for IOS.
It is available from the App Store
This first release is free and includes the Casio Fx-8000g, TI-57, HP-41CX, PC-1245, PC-1350 and PC-1500. The CE-126P printer and the CE-150 plotter are also available.
It works on iPhone and iPad with iOS12 and above.
The full PockEmul for IOS with near 60 emulated models will be released later.
I had to make some deep changes on the apps to work on IOS because the system implies a lot of constraints on Threads and CPU consomption.
It is my first IOS application. The only physical IOS device I own is an iPad so my only tests on iPhone are done on the simulator.
Feedbacks are warmly welcome. (contact@pockemul.com)
[Image: ipad.jpg]
Rémy
03-06-2021, 01:15 PM
RE: PockEmul for IOS now available
Looks very good!
Any way to modify the run speed of the emulations ? I laughed at how slow the TI-57 factorial program that was pre-loaded ran. :-)
Of course, that's the way the TI-57 really ** is ** so it's perfect. haha.
Great job.
Gene
03-06-2021, 01:22 PM
(03-06-2021 01:15 PM)Gene Wrote:  Any way to modify the run speed of the emulations ? I laughed at how slow the TI-57 factorial program that was pre-loaded ran. :-)
Yes !
Double tap on the TI-57 display to show the context menu. In the Configuration/CPU Speed, choose Maximum speed.
On my iPad I can run it up to 302x the nominal speed. :-)
03-06-2021, 08:29 PM
Great work and amazing emulators. It even has the Epson HX-20. I use the Android PockEmul app which works great. I find it very useful to try out things for which I don't want use my physical machine in case my experiment does not work, especially when it involves plotting so I don't lose plotter pen ink and paper that are very hard to get.
Any chance to see a HP-71B emulator in the future? There are HP-71B emulators out there already, but a PockEmul version may look and feel more realistic than those.
Looking forward to your future Android and iOs PockEmul updates.
- Rob
"I can count on my friends" -- HP 71B,Prime|Ti VOY200,Nspire CXII CAS|Casio fx-CG50...|Sharp PC-G850,E500,2500,1500,14xx,13xx,12xx...
03-06-2021, 08:38 PM
(03-06-2021 08:29 PM)robve Wrote:  Great work and amazing emulators. It even has the Epson HX-20. I use the Android PockEmul app which works great. I find it very useful to try out things for which I don't want use my physical machine in case my experiment does not work, especially when it involves plotting so I don't lose plotter pen ink and paper that are very hard to get.
- Rob
Thank you so much for your support.
The next available model in Android will be the TI CC40.
Then I will work on the IOS full release.
I will take a look on the HP-71 to estimate the amount of work. The main issue will be to buy one (it is expensive) because it is quite complicate to emulate a device without testing on a real one.
03-06-2021, 10:40 PM
(03-06-2021 08:38 PM)remy Wrote:  The main issue will be to buy one (it is expensive) because it is quite complicate to emulate a device without testing on a real one.
Perhaps someone on this forum can lend their HP71B to remy - because it sure would be good to have the HP71B in PockEmul.
03-07-2021, 03:31 PM
Remy, would love to see an emulation of the SR-56 if possible sometime. The TI-57 predecessor.
03-07-2021, 03:44 PM
(03-07-2021 03:31 PM)Gene Wrote:  Remy, would love to see an emulation of the SR-56 if possible sometime. The TI-57 predecessor.
Noted.
For information here are the next planned models in PockEmul :
  • TI CC-40 : next release
  • PC-1211 simulator : in alpha stage. I still have some issues
  • Casio FP-200 : finished. Needs test
  • TI-58 : finished. Needs test
  • TI-59 : finished. Needs test
  • HP-48 : finished. Needs test.
  • Panasonic HHC : finished. Needs test
  • FX-702P Simulator : not yet started
  • PB-100 Simulator (or MK-85 emulator ) : not yet started
  • HP-71b : to investigate
  • SR-56 : to investigate
03-07-2021, 03:53 PM
Remy,
Hats off to you (as the French say .. Chapeau). You are now officially the Napoleon of emulators! I have always loved the Windows implementations, and now you bring this beauty to the IOS.
Looking forward to a more complete version!
Namir
03-11-2021, 03:40 AM (This post was last modified: 03-11-2021 03:42 AM by Xorand.)
Downloaded and installed. Nice work so far. Running on iPhone 11 Pro Max. Found this small UI issue when in landscape mode, selecting which calculator/computer to run (note calc/pc name is pushed up off screen):
[Image: i-tHbQZ2K-L.png]
03-11-2021, 09:36 AM
Thank you for your feedback.
03-11-2021, 06:31 PM
(03-11-2021 09:36 AM)remy Wrote:  Thank you for your feedback.
No problem. So far it has been pretty solid. Looking forward to additional machines. Will gladly pay an upgrade fee to have a larger selection.
03-11-2021, 10:52 PM
(03-11-2021 06:31 PM)Xorand Wrote:  No problem. So far it has been pretty solid. Looking forward to additional machines. Will gladly pay an upgrade fee to have a larger selection.
If the same pricing model as for Android (subscription) is used that might be a disapointment.
03-11-2021, 10:56 PM
(03-07-2021 03:44 PM)remy Wrote:  [*] PB-100 Simulator (or MK-85 emulator ) : not yet started
You could take a look here: https://github.com/digihori/pokecom2 for a working Casio PB-100 emulator. The same guy also has some Sharp emulators in his Github repo but they require original romdumps, some of them can be found in other emulator sources.
03-11-2021, 11:48 PM
It is interesting for the PB-100 simulator.
Regarding Sharp emulators, PockEmul already emulates almost all of them.
