HP41-CV Troubleshooting
07-26-2020, 05:38 AM
When putting in new batteries / turning on my HP-41CV I'm either getting
1) a high pitched squeal
2) a set of characters on the screen
https://imgur.com/V363v29
I have tried a hard reset without success. The batteries are new and the battery terminals are in good condition without corrosion.
I have also tried the options here
https://www.hpmuseum.org/cgi-sys/cgiwrap...i?read=149
What can I try next.
Many Thanks
07-29-2020, 11:33 PM (This post was last modified: 07-29-2020 11:34 PM by Diego Diaz.)
RE: HP41-CV Troubleshooting
Hard to tell without some pictures (from different angles) of your CV. Most common cause of failure on the 41 series (mainly on full-nut type) is the broken screw post syndrome.
You may want to open your calc and check if the screw posts are not damaged/broken.
Share some pictures if you're not sure about what to look for.
Regards.
Diego.
"Do not suppose, check it twice."
