hp41 flying goose, program execution indicator
06-01-2014, 10:07 PM
Greetings,
Is there a way to 'reactivate' the flying goose after displaying the ALPHA register. I have output that persists on the screen for quite a while and it misleads you into thinking the program has locked up. Is there any way to flick the execution indicator back on? Regards Todd |
06-01-2014, 11:47 PM
RE: hp41 flying goose, program execution indicator
(06-01-2014 10:07 PM)twdeckard Wrote: Is there a way to 'reactivate' the flying goose after displaying the ALPHA register?Hello, CLD is the word you're looking for:-) HTH Regards -- Ray |
06-02-2014, 01:18 AM
RE: hp41 flying goose, program execution indicator | |||
06-02-2014, 01:46 PM
You are a real hero if you can make it the goose fly backwards ![/b]
Regards, Meindert |
06-02-2014, 02:01 PM
(06-02-2014 01:46 PM)MeindertKuipers Wrote: You are a real hero if you can make it the goose fly backwards ![/b] IIRC, eleven labels in a row has that effect, because the goose moves forward 11 spaces so quickly that it appears to have flown backwards one space. A backwards FACING goose is more difficult, but doable. <0|ɸ|0> -Joe- |
06-02-2014, 02:14 PM
(06-02-2014 02:01 PM)Joe Horn Wrote:(06-02-2014 01:46 PM)MeindertKuipers Wrote: You are a real hero if you can make it the goose fly backwards ![/b] Just my usual blast from the past... :) Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
06-03-2014, 02:15 AM
(06-02-2014 02:14 PM)Massimo Gnerucci Wrote: Just my usual blast from the past... That thread mentions "goose droppings". Some can be seen here: http://hhuc.us/2009/index.htm Check out other pages in that HHC 2009 website for some other fun HP-41 "screen captures", some of which are animated. Only the real HP-41 addicts will recognize all of them. <0|ɸ|0> -Joe- |
06-03-2014, 05:12 AM
(06-02-2014 02:01 PM)Joe Horn Wrote: A backwards FACING goose is more difficult, but doable. And a backwards facing goose flying backwards is the second derivative, so to speak ;-) There are two functions in the "Sudoku & Sound" module that allow for these without any synthetics wizardry: "LEFT" and "GOOSE" - simply intersperse them in the FOCAL code and voila, your goose obeys your commands... I got those from the NFC EPROM, written by Nelson C. Crowle - remember the AECROM? See page 9 in the attached doc. |
06-03-2014, 05:42 AM
(06-03-2014 02:15 AM)Joe Horn Wrote:(06-02-2014 02:14 PM)Massimo Gnerucci Wrote: Just my usual blast from the past... Whoa! A real Goose-fest... ![]() Thank you Joe Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
06-03-2014, 05:50 AM
06-03-2014, 06:08 AM
(06-03-2014 05:50 AM)Ángel Martin Wrote:(06-03-2014 05:42 AM)Massimo Gnerucci Wrote: Whoa! A real Goose-fest... Gotcha! What about a goose-festival? ![]() Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
