I have question can HP Prime Solve these two functions?
05-10-2020, 01:16 PM
Hi, ?:
Can HP Prime Solve this!
for two equations together find one answer!
X**3+9X**2Y=10
Y**3+XY**2=2
can someone tell me is this a possible or not.
I have tried in all the solvers and have come up with only single answers for both equations separately.
Thank You.
Hope everyone is safe in these trying times.
05-10-2020, 10:55 PM (This post was last modified: 05-10-2020 10:56 PM by pinkman.)
RE: I have question can HP Prime Solve these two functions?
Maybe the people here didn’t answer because they think you should have found by yourself.
Did you really try on a Prime?
You can find the numeric solutions in CAS view, using fsolve([eq1 eq2], [x y])
I let you do that, I give you the graphic view (green plan is z=10, eq2 is multiplied by 5 to see the intersections of eq1, eq2, z=10)
Attached File(s) Thumbnail(s)
05-11-2020, 08:59 AM
[Image: system.jpg]
Best,
Aries Smile
05-11-2020, 09:37 AM
tom234, did you try CAS command solve?
solve([(x^3+9*x^2*y) = 10,(y^3+x*y^2) = 2],[x,y])
BTW how is previous post relevant to "Can HP Prime Solve..?" is beyond me. In addition, the shown result is considerably incomplete.
Geocaching Coords Solver, Number of triangles Puzzle
05-11-2020, 12:10 PM
(05-11-2020 09:37 AM)chromos Wrote:  tom234, did you try CAS command solve?
BTW how is previous post relevant to "Can HP Prime Solve..?" is beyond me. In addition, the shown result is considered incomplete.
Yes, I am in CAS and this is what it looks like Can it do (A+B)^3 factorials?
Like:
https://www.youtube.com/watch?v=dVs26SSUJSA. That the that's the equation on Youtube can it solve for this?
05-11-2020, 12:20 PM
(05-11-2020 08:59 AM)Aries Wrote:  [Image: system.jpg]
Best,
Aries Smile
Thats not the answer on the TI
The answer and solve we are looking for is at the end of this video.
see equation at start fast forward to see the solution.
can it handle x^3(?) and xy^2(x*y^2)
05-11-2020, 12:31 PM
(05-10-2020 10:55 PM)pinkman Wrote:  Maybe the people here didn’t answer because they think you should have found by yourself.
05-11-2020, 12:37 PM
I think the prime can only handle x^2 and cannot handle x^3 or higher.
Its Algebra:https://www.youtube.com/watch?v=dVs26SSUJSA
05-11-2020, 03:35 PM
Hi Tom,
Perhaps the syntax of your entry was incorrect. I entered the 2 equations as in the attached screen shot and got the 1,1 answer from the TI Inspire as well as 2 other solutions (which makes sense for third order equations).
Take care & good luck
05-11-2020, 05:14 PM
(05-11-2020 03:35 PM)swagner53 Wrote:  I entered the 2 equations as in the attached screen shot and got the 1,1 answer from the TI Inspire
Actually, this is a 9-degree equation, with 3 real and 6 complex solutions
eqn2: y^3 + x*y^2 = 2     → x = (2-y^3)/y^2
eqn1: x^3 + 9*x^2*y = 10, substitute x from above
(8*y^9 - 30*y^6 + 24*y^3 + 8) / y^6 = 10
8*(y^9 - 5*y^6 + 3*y^3 + 1) = 0
8* (y^3 - 1) * ((y^3 - 2)^2 - 5) = 0
y^3 = 1, 2 ± √5
y = 1, φ ,1-φ, w, wφ ,w(1-φ), w², w²φ, w²(1-φ),       where w=exp(i*pi/3), φ=(1+√5)/2
05-11-2020, 05:49 PM
Hi Albert,
You are absolutely correct. I did not have COMPLEX checked in the CAS settings. When I did, the Prime returned all 9 solutions - 3 real and 6 complex.
Thanks, Steve
05-11-2020, 06:34 PM
(05-11-2020 03:35 PM)swagner53 Wrote:  Hi Tom,
I did exactly what you did and got nothing just empty brackets.
05-11-2020, 06:35 PM
(05-11-2020 05:49 PM)swagner53 Wrote:  Hi Albert,
Thanks, Steve
I did have complex on!
05-11-2020, 06:45 PM
Thanks, Steve
got this is something wrong with this calculator
05-11-2020, 06:47 PM
y^3 = 1, 2 ± √5
05-11-2020, 08:07 PM
Try putting braces around the two equations, as in a list.
05-11-2020, 08:26 PM
Also, you are using "xy" in the equations, and probably need to specify "x*y", but I'm no Prime expert and maybe implicit multiplication is allowed in some places?
05-11-2020, 08:31 PM
Thank you after several tries at this I put the calculator into Algebraic mode and entered your formula above the way you did above.
The blue key bracks were Matrix in Textbook mode however, in Algebraic mode they were square [] the answers you got were now what I got and what the video got.
I have to say there was no way to get square brackets in text mode.
The answer you got was for me in Algebraic mode in Cas solve.
05-11-2020, 08:43 PM
This has been a day-long problem. I was ready to send it back.
1. I reset the Virtual HP Prime on the computer and got some better answer.(in Text Mode).
2. I reformated my C drive on the HP Prime calculator.
3. The final thing is I change to Algebraic mode and entered it as you all suggested.
That when the answer in all the fractions and the 1,1 was realized.
4. Remember I said I could not get it in CAS Solve (Text MOde) I just switched it and it came back with the same right answer. How is this possible is this thing possessed.
or what? Hell, that's some kind of crazy.
05-11-2020, 10:18 PM
Numerical and symbolic solve. Still don’t understand what’s wrong.
