(12C) Mastermind on HP12c
03-29-2020, 08:07 PM (This post was last modified: 05-03-2020 07:37 PM by Gene.)
There is my first post for the MoHPC
I wrote this program of Mastermind for the HP12c because it's become my usual calculator at work
I had to adapt my original program, initially written for calculators like HP15c and HP41c... So, I adopted a new way !
This is :
- first period with the creation of the code to break (5 digits from 1 to 9)
- entry of the attempt to find the code
- second period with the comparison digit by digit between the code to break and the entry. Black positions to win ! In the same time, creation of 2 virtual arrays (code to find // attempt) of digits with the non-black digits.
- third period to assimilate the active positions in the 2 arrays. White positions in win !
- gives back the result and waits for a new attempt
Attached File(s)
.pdf  HP12C - Mastermind - lmaN pour MoHPC.pdf (Size: 33.18 KB / Downloads: 25)
04-10-2020, 12:35 PM
RE: Mastermind on HP12c
The same listing for HP12C with included example
(Thank you for you practical note, rprosperi)
Attached File(s)
.pdf  HP12C - Mastermind + example - lmaN for MoHPC - 20200410.pdf (Size: 37.5 KB / Downloads: 15)
