Weird Issue with Solve Function
03-26-2020, 07:36 PM
So this is how the problem should look and the answer as well: https://www.wolframalpha.com/input/?i=so...%2Cy%5D%29
When I type this into the Prime though, I get nothing. Just the dreaded [[]].
Trying to graph the two equations gives the yellow exclamation mark before going into the graphing screen with nothing on it.
[Image: 0QtdwVF.png]
03-27-2020, 12:50 AM
RE: Weird Issue with Solve Function
Change your plot setting to this:
and you should get this:
-road
03-27-2020, 01:12 AM
And if you modify your second equation slightly you get:
I'm not sure why your original form doesn't work.
-road
03-27-2020, 01:22 AM
Have a value stored for x or y?
TW
03-27-2020, 01:38 AM
Nope:
03-27-2020, 04:53 AM
Thanks roadrunner! Hopefully this is not a bug.
(03-27-2020 01:22 AM)Tim Wessman Wrote:  Have a value stored for x or y?
Yeah, I don't have a value stored either.
03-27-2020, 07:42 AM
Indeed, bug confirmed and fixed.
03-27-2020, 11:13 AM
This is more difficult. We're dealing with big numbers.
Others tried to solve this case before me.
I've also tried to solve this system of equations. I did it by looking for an approximation (lower boundary, upper boundary). See it in the screenshots. HP PRIME is a very powerful calculator. It solves almost every equation, inequality, equation system. But if there are problems, the outstanding Parisse will fix it quickly.
03-27-2020, 05:36 PM
(03-27-2020 11:13 AM)Jan 11 Wrote:  This is more difficult. We're dealing with big numbers.
If only we could have the full power of χCas in the HP Prime. Separating the (external) libraries that contain ©opyright or other issues(*) so that a note powerful HP Prime would be available. Also the bug fixes would be more universal thus requiring less version maintaining efford.
VPN
(*) Software library licence problem requiring everything using it to become public?
