Restore to hardware calculator broken?
03-23-2020, 11:59 PM (This post was last modified: 03-24-2020 01:26 AM by Orome.)
Does the CK work to "restore" from a virtual calculator to a hardware calculator?
Here's what I see (100% of the time):
  1. Make a backup from either an iOS Prime or the macOS Prime
  2. Use backup from (1) to restore to a hardware Prime
  3. Restore appears successful
  4. Try any operation on the hardware calculator
  5. Hardware calculator crashes and reboots, erasing all memory
Also, in step 3, the target calculator gets renamed uselessly to match the source calculator (which is not what happens in a virtual-virtual backup+restore).
Any ideas. Basically this means I can't customize a virtual calculator rand then apply those customizations to a hardware calculator.
03-24-2020, 12:40 AM
RE: Restore to hardware calculator broken?
(03-23-2020 11:59 PM)Orome Wrote:  Does the CK work to "restore" from a virtual calculator to a hardware calculator?
Pretty sure Tim has confirmed that backups should be compatible across devices... hopefully he'll see this and confirm.
Try fully resetting the target machine before the restore, it may make a difference.
Also, any possibility the backup file was damaged?
As for device name, I'd guess that it would restore the original device's name to new device, but don't recall testing that... will have to look...
03-24-2020, 08:40 PM
rprosperi Wrote:  Try fully resetting the target machine before the restore, it may make a difference.
I've tried multiple different backups and none work.
How should I reset? Poking the reset hole doesn't fix the problem.
Also: CK crashes when I back up to my hardware prime.
#StayTheFuckHome
03-24-2020, 09:51 PM
From here: https://www.hpmuseum.org/forum/thread-818.html
"0.19) How to reset the Prime to recover from some unwanted issues (All Firmware releases including 7820), by Tim Wessman
Warning: these procedures will wipe the user's work.
Make sure you have a backup (Use the Connectivity Kit for that).
a) First approach - Wipe out all memory:
Press ON-APPS-ESC (all 3 together) and release.
b) Second approach - Reset to factory defaults:
Reboot the Prime and hold the three keys with the orange C F O letters. This will get you into the factory test menu, and you can format the drive. Once you see the "EA656 DIAGNOSTIC" Screen Menu, press 4 for FLS Utility, 3 for Format Disk C, then ENTER. Once finished, press ESC to back out into the main menu and press 9 to reset and reboot.
http://www.hpmuseum.org/forum/thread-397...l#pid36148"
While trying to not sound like I'm saying RTFM, I'd say you should at least skim this section to see the breadth and depth of articles already posted, there is a lot of content there that should help a lot of these kinds of questions.
03-24-2020, 09:59 PM
rprosperi Wrote:  While trying to not sound like I'm saying RTFM, I'd say you should at least skim this section to see the breadth and depth of articles already posted, there is a lot of content there that should help a lot of these kinds of questions.
Yes, I saw that (as well as several other techniques, here and elsewhere, before asking — as you say "a lot"). The question is, which should I use in this case: which did you mean by "reset"?
03-24-2020, 10:15 PM
For the situation you have, I'd use the 'reset to factory defaults' (CFO reset and format drive) to try to get the fullest (or most thorough) 'wipe', ensuring any possible corruption is removed. I've no idea if this will fix the problem, but doing so removes all possibilities (and there are many) of the problem being a corrupted target unit.
03-24-2020, 10:45 PM
rprosperi Wrote:  As for device name, I'd guess that it would restore the original device's name to new device, but don't recall testing that... will have to look...
As near as I can tell (multiple crashes makes it tedious) the destination calculator gets the name of the backup source calculator, which results in two calculators with the same name, which CK doesn't like, so it gets confused and crashes.
So the only way to make things work if the goal is to copy settings from one calculator to another using a backup, is to never have two calculators connected to the CK at the same time, and to be sure to disconnect the destination calcuator rename it with a distinct name before reconnecting it.
This can't be the intended behavior, so I must be missing something.
What is the correct method for copying the state of one calculator to another using CK?
#StayTheFuckHome
