NP-25 Calculator 3d case and keys design
02-25-2020, 02:20 AM (This post was last modified: 02-26-2020 01:34 AM by Craig Bladow.)
I've posted the .stl files and assembly instructions for the NP-25 calculator case and keys on Thingiverse.
Attached File(s) Thumbnail(s)
Check out NQ41!
02-25-2020, 07:21 AM
RE: NP-25 Calculator 3d case and keys design
(02-25-2020 02:20 AM)Craig Bladow Wrote:  I've posted the .stl files and assembly instructions for the NP-25 calculator case and keys on Thingiverse.
[Image: Screenshot%20from%202020-02-24%2019-23-55.png?dl=1]
Thank you.
Backslash? Wink
Greetings,
    Massimo
02-26-2020, 01:35 AM
(02-25-2020 07:21 AM)Massimo Gnerucci Wrote:  Backslash? Wink
I couldn't figure out the problem so I just attached the file. Thanks for the feedback as it appeared to be working immediately after posting.
Check out NQ41!
02-26-2020, 04:08 AM
I think Massimo was referring to the backslash symbol on the divide key on the lower-left key of the completed case. The original HP-25 had an obelus division symbol on this key.
02-26-2020, 04:28 AM (This post was last modified: 02-26-2020 04:30 AM by Craig Bladow.)
(02-26-2020 04:08 AM)Steve Simpkin Wrote:  I think Massimo was referring to the backslash symbol on the divide key on the lower-left key of the completed case. The original HP-25 had an obelus division symbol on this key.
Oh, thank you for the explanation, the symbol choice is a combination of the readily available font and limited time to find a work around. The proper division symbol did not print clearly with the equipment I am using. All of the key legends could be made clearer by printing on a resin printer or using a smaller nozzle diameter on an fdm printer.
Check out NQ41!
02-26-2020, 11:48 AM
Yes Steve, that was it.
It's strange that "\" prints out better than "/" while I understand that "÷" can be problematic if resolution is coarser.
Greetings,
    Massimo
02-26-2020, 01:37 PM
(02-26-2020 11:48 AM)Massimo Gnerucci Wrote:  It's strange that "" prints out better than "/" while I understand that "÷" can be problematic if resolution is coarser.
I don't remember if there was a issue with "\" vs "/". I just checked NQ41 and it uses "/" for division.
Check out NQ41!
03-01-2020, 10:34 PM
Here is what the keys look like with an obelus symbol. The 'dots' above and below the horizontal bar did not print well on my 3D printer so it more resembled the minus symbol. I've sent this to a friend who has a resin printer to see how well it prints.
Check out NQ41!
