DM41X – Running Modules?
02-15-2020, 04:34 PM
So, I followed the instructions and now have two modules in the 'Active Modules' section. The manual states 'Press [ ENTER ] to accept Active Modules list.
Now the module should be active.'
When I do that, I'm returned to the stack display. How do I actually run what's on the modules?
TIA,
Tim
___________________________
HP11C, HP12C, HP25, HP32E, HP33E, HP33C, HP35, HP35S, HP41C, HP45, HP48SX, HP67, DM41 X
02-15-2020, 05:23 PM (This post was last modified: 02-15-2020 05:32 PM by Massimo Gnerucci.)
RE: DM41X – Running Modules?
(02-15-2020 04:34 PM)Ignatz Wrote:  So, I followed the instructions and now have two modules in the 'Active Modules' section. The manual states 'Press [ ENTER ] to accept Active Modules list.
Why don't you ask this on SM forum?
41 - 101: CATALOG 2 is your friend.
R/S and ENTER will show you all the functions available.
Quote:to review all of the functions associated with currently plugged-in extensions.
Greetings,
    Massimo
02-16-2020, 11:29 AM
Whoops...
I thought I was on the SM forum! the layout is very similar...
TIA,
Tim
