(42S) HP 67 Calendar Functions (Standard Pac)
01-05-2020, 03:43 AM
This is a pretty straight conversion of the Calendar Functions program included in the HP 67 Standard Pac. I've only made a few changes to it in the conversion:
1. Added a nice 42S menu to replicate the key labels on the card.
2. Replaced registers A, I, and C with 00, 01, and 02 respectively.
3. Replaced some 67 idioms with their 42S counterparts (F? 3 to FS?C 22, STOi to STO IND 01, etc.).
4. Replaced usage of divide-FRAC-multiply with the MOD operator to eliminate rounding error. This also eliminated the need for LBL E to call LBL 3, and the LBL 3 step was removed.
Usage
For more detailed instructions and examples, see the HP 67 Standard Pac, page 04-01. Here's the basics:
DT1: Date 1
DT2: Date 2
DAYS: Days (number of days between DT1 and DT2)
W.D: Weeks + Days (numbers of weeks and days between DT1 and DT2, in W.D format)
DT1, DT2, DAYS, and W.D act as both inputs and outputs. To input a value, enter it in X, and press the appropriate key. To calculate a value, press the key without entering any data. After entering any two of these values (but only one of either DAYS or W.D), you can calculate the other two values.
→DOW works independently. Enter a date into X, and press the →DOW key to calculate the day of the week. 0=Sunday, 1=Monday, 6=Saturday.
All dates are entered in MM.DDYYYY format, and this program is accurate for dates between March 1, 1900 and February 28, 2100.
00 { 294-Byte Prgm }
01▸LBL "DATE67"
02 CLMENU
03 "DT1"
04 KEY 1 XEQ A
05 "DT2"
06 KEY 2 XEQ B
07 "DAYS"
08 KEY 3 XEQ C
09 "W.D"
10 KEY 4 XEQ D
11 "→DOW"
12 KEY 5 XEQ E
13▸LBL 10
14 MENU
15 STOP
16 GTO 10
17▸LBL A
18 RCL 04
19 RCL 02
20 -
21 3
22 GTO 00
23▸LBL B
24 RCL 03
25 RCL 02
26 +
27 4
28▸LBL 00
29 STO 01
30 R↓
31 365.25
32 STO 05
33 30.6001
34 STO 06
35 R↓
36 R↓
37 FS?C 22
38 GTO 01
39 STO IND 01
40 122.1
41 -
42 RCL 05
43 ÷
44 IP
45 STO 09
46 RCL 05
47 ×
48 IP
49 RCL IND 01
50 -
51 +/-
52 STO 00
53 RCL 06
54 ÷
55 IP
56 STO 07
57 RCL 00
58 X<>Y
59 RCL 06
60 ×
61 IP
62 -
63 STO 08
64 RCL 07
65 1
66 RCL 08
67 %
68 -
69 -
70 RCL 07
71 14
72 ÷
73 XEQ 02
74 RCL 09
75 1ᴇ6
76 ÷
77 +
78 RTN
79▸LBL 01
80 R↓
81 ENTER
82 IP
83 STO 07
84 -
85 100
86 ×
87 ENTER
88 IP
89 STO 08
90 -
91 1ᴇ4
92 ×
93 STO 09
94 RCL 07
95 1
96 +
97 ENTER
98 1/X
99 0.7
100 +
101 +/-
102 XEQ 02
103 RCL 06
104 ×
105 IP
106 RCL 09
107 RCL 05
108 ×
109 IP
110 +
111 RCL 08
112 +
113 STO IND 01
114 1720982
115 +
116 RTN
117▸LBL 02
118 IP
119 STO+ 09
120 12
121 ×
122 -
123 RTN
124▸LBL C
125 STO 02
126 FS?C 22
127 RTN
128 RCL 04
129 RCL 03
130 -
131 STO 02
132 RTN
133▸LBL D
134 FS?C 22
135 GTO 04
136 XEQ C
137 ENTER
138 ENTER
139 7
140 ÷
141 IP
142 X<>Y
143 7
144 MOD
145 10
146 ÷
147 +
148 RTN
149▸LBL 04
150 ENTER
151 IP
152 7
153 ×
154 X<>Y
155 FP
156 10
157 ×
158 +
159 STO 02
160 RTN
161▸LBL E
162 SF 22
163 RCL 05
164 5
165 XEQ 00
166 RCL IND 01
167 5
168 +
169 7
170 MOD
171 END
.zip  DATE67.zip (Size: 435 bytes / Downloads: 2)
