How do I get CAS to evaluate a Python-in-CAS function? (Solved)
12-12-2019, 11:33 PM (This post was last modified: 12-13-2019 09:21 PM by StephenG1CMZ.)
How do I get this function to evaluate...
All I get is the name of the function returned
(The Python string syntax may need correcting too
CAS file:
#cas
HAMMINGCAS():=
def hammingdistance(s1, s2) -> int:
    """Return the Hamming distance between equal-length sequences."""
    if len(s1) != len(s2):
        raise ValueError("Undefined for sequences of unequal length.")
    count = 0
    for ii in s1
     el1 = s1(ii)
     el2 = s2(ii)
     if el1 != el2:
      count = count+1
    return count
    """return sum(el1 != el2 for el1, el2 in zip(s1, s2)) """
#end
PPL file:
 EXPORT TRY()
  LOCAL ST1:="AB";
  LOCAL ST2:="AB";
  RETURN CAS("eval(hammingdist(ST1,ST2))");
EXPORT HAMMING()
  //def hamming_distance(s1, s2) -> int:
  // """Return the Hamming distance between equal-length sequences."""
  //  if len(s1) != len(s2):
  //      raise ValueError("Undefined for sequences of unequal length.")
  //  return sum(el1 != el2 for el1, el2 in zip(s1, s2))
Stephen Lewkowicz (G1CMZ)
ANDROID HP PRIME APP NO LONGER WORKS OFFLINE?
12-13-2019, 06:18 AM
RE: How do I get CAS to evaluate a Python-in-CAS function?
Remove
HAMMINGCAS():=
and
Then check your function from the shell.
Your loop is incorrect, it should be for ii in range(size(s1)): and you should write s1[ii] and s2[ii] (with 0 starting index, run index:=0 if required)
BTW, this is called hamdist in Xcas.
12-13-2019, 03:48 PM (This post was last modified: 12-13-2019 04:06 PM by StephenG1CMZ.)
The function works fine in CAS and PPL shell, and now from PPL
My error was naming the function hamming distance but calling hammingdist.
Fixing that it evaluates as expected.
CAS:
#cas
def hammingdist(s1, s2) -> int:
    count = 0
     if s1[ii] != s2[ii]:
      count = count+1
    return count
PPL:
 EXPORT TRY()
  LOCAL ST1:="AB";
  LOCAL ST2:="AB";
  PRINT( CAS("(hammingdist(ST1,ST2))") );
  PRINT(CAS("sum(N^2,N,1,5)")); //works
  RETURN CAS("(hammingdist(ST1,ST2))");
