Matrix Rotation of elements - Algorithms
12-12-2019, 02:37 PM
For no particular reason I've been looking into some matrix operations not mainstream, such as the element rotation, or "layer rotation". Note this is not the same as the "Rotation Matrix" used in transfromations theory - [ or is it? Somehow these two are begging to be connected in my mind... ]
Surely some scarce references exist (see here, here, and here) but I wonder if friendlier algorithms have been worked out that allow for an easier implementation using our trusted toolset in the Advantage and SandMatrix modules...
So to clarify, I'm after a single-element rotation algorithm, either clockwise or anti-clockwise. Rotating the entire matrix 90 degrees is actually very simple using the transpose and column swapping , but a single element is much harder.
Anyy inputs will be appreciated.
12-12-2019, 03:31 PM
RE: Matrix Rotation of elements - Algorithms
(12-12-2019 02:37 PM)Ángel Martin Wrote:  I wonder if friendlier algorithms have been worked out
Which units are in play? 48xx? My 39gII arrived this week - maybe that?
Csaba
12-12-2019, 03:59 PM
(12-12-2019 03:31 PM)Csaba Tizedes Wrote:  Which units are in play? 48xx? My 39gII arrived this week - maybe that?
RPN if possible...
12-15-2019, 06:16 AM (This post was last modified: 12-16-2019 12:54 PM by Ángel Martin.)
here's a start, surely not the best approach but it seems to do the job:
for an (m x n) matrix, the rotated matrix (one single step, clockwise) bij is given as follows:-
FOR k = 0 TO int(m/2)-1 ; current layer
FOR j = k+1 TO (n-1-k) ; top row rightwards
b(1+k),(j+1) = a(1+k),j
NEXT j
FOR i = (1+k) TO (m-1-k) ; rightmost column downwards
b(i+1),(n-k) = a i,(n-k)
NEXT i
FOR j = (n-k) TO (2+k) STEP -1 ; bottom row leftwards
b(m-k),(j-1) = a(m-k),j
NEXT j
FOR i = (m-k) TO (2+k) STEP -1 ; leftfmost column upwards
b(i-1),(1+k) = a i,(1+k)
NEXT i
NEXT k ; next layer
Edited: corrected typos in indexes
12-17-2019, 10:46 AM (This post was last modified: 12-17-2019 10:47 AM by Ángel Martin.)
I don't think I said it before but when it comes to this kind of programs I really hate RPN, or more appropriately I hate FOCAL (let's put the blame where it belongs).
Really what in BASIC is a simple and quick affair (see previous post) becomes tricky, sticky and error prone beyond relief using FOCAL - all those sub-indexes and counters - all pitfall-ridden!
Regardless, the routine is done at last - will post it in the program section in a couple of days.
12-17-2019, 02:22 PM
My first idea was that it requires something "matrix-to-list" stuff and the lists can be more flexible manipulate. (I totally agree: for matrices the BASIC is better Tongue)
The second was, how the HP 15C reorganize the elements, when I change the dimension of the matrices?!?
The third was I need only a "row-extractor" and I will use it to copy one row into list, than I transpose the matrix and again extract and transpose and extract... Or something similar, and of course I must to put back the rotated list elements with the same way: put-transpose-put-transpose...
The fourth was: this is something "walking-inside-a-spirale-labirynth": I started in the center and if I found a wall, I turn left (or right) and again until I found the last element. If I copy the values into a list during my way, I can transform my matrix into a list.
This is a good exercise, I will workin' on it - after this Friday...
Csaba
12-17-2019, 03:51 PM (This post was last modified: 12-17-2019 04:04 PM by Ángel Martin.)
I actually use a scratch matrix and copy elements one at a time from the source to the scratch, and when done do the bulk renaming source = scratch.
Here's the routine. you need to be familiar with the SandMatrix functions (an extension of the Advantage, itself an extension of the CCD ARRAY group...). The element copying happens in LBL 05 towards the end of the program.
PHP Code:
1    LBL "M<)R"
2    "|-,#"
3    MAT=
4    DIM?
5    2
6
/         m/2
7    INT        int
(m/2)
8    E
9
-          int(m/2) - 1
10   I
<>J
11   STO 00     0
,00(int(m/2))
12   LBL 00
13   DIM
?       m,00n
14   FRC        0
,00n
15   RCL 00     k
,00l
16   INT        k
17   E
18
+          1+k
19   STO 02
20   I
<>J       0,00(1+k)
21   -          0,00(n-k-1)
22   RCL 02     k+1
23
24   STO 01     (k+1),00(n-k-1)
24   LBL 01
25   E
26   XEQ 05     shift row
27   ISG 01
28   GTO 01
do next row
29   DIM
?       m,00n
30   INT        m
31   RCL 01     k
+1
32
-          m-k-1
33   I
<>J       0,00(m-k-1)
34   RCL 02     1+k
35
36   STO 01     (k+1),00(m-k-1)
37   DIM?       m,00n
38   RCL 00
39   I
<>J       x,00k
40
-          m,00(n-k)
41   FRC        0,00(n-k)
42   STO  02    0,00(n-k)
43   LBL  02
44   E          increase row
45   XEQ 06     shift column
46   ISG  01    NEXT j
47   GTO  02
do next column
48   DIM
?       m,00n
49   FRC        0
,00n
50   I
<>J       n
51   RCL  00
52   INT        k
53
-          (n-k)
54   E
55   LASTX      k
56
+          2+k-1
57   I
<>J       0,00(2-k-1)
58   STO 03     0,00(2-k-1)
59   +          (n-k),00(2-k-1)
60   STO  01    (n-k),00(2-k-1)
61   DIM?       m,00n
62   RCL  00    k
,00l
63
-          (m-k),00(n-l)
64   INT        m-k
65   STO  02
(m-k)
66   LBL  03
67
-1         decrease colum
68   XEQ  05    shift row
69   DSE  01    NEXT i
70   GTO  03
do next row
71   DIM
?       m,00n
72   RCL  00    k
,00l
73
-          (m-k),00(n-l)
74   INT        m-k
75   RCL 03     0
,00(2-k-1)
76   +
77   STO  01    (m-k),00(2+k-1)
78   RCL  00
79   INT        k
80   E
81
+          k+1
82   I
<>J       0,00(1+k)
83   STO  02    0,00(1+k)
84   LBL  04
85
-1
86   XEQ  06    shift column
87   DSE  01    NEXT j
88   GTO  04
do next column
89   ISG  00    NEXT k
90   GTO  00
do next layer!
91   ASWAP
92   MAT
=       Make Matrix Equal
93   PURFL
94   MNAME
?     restore Matrix Name
95   RTN
96   LBL  05
97   I
<>J       0,001
98   RCL  01
99   INT
100  I
<>J        i or j
101  GTO  07     0
,00(1+k)
102  LBL  06
103  RCL  01
104  INT
105  LBL  07
106  RCL  02
107
108  +
109  LASTX
110  MSIJA      Sets Pointer
111  MR         Recall Element
112  RCL  Z
(1)
113  ASWAP
114  MSIJA      Sets Pointer
115  X
<>Y       Store by Row
116  MS
117  ASWAP
118  END
12-17-2019, 04:18 PM
Hi, Ángel:
(12-17-2019 10:46 AM)Ángel Martin Wrote:  Really what in BASIC is a simple and quick affair (see previous post) becomes tricky, sticky and error prone beyond relief using FOCAL - all those sub-indexes and counters - all pitfall-ridden!
Hey, "Mr. Translator", it's "beyond belief", not "beyond relief". The "r" is far from the "b" in the keyboard so that's unlikely to be a typo. Wink
After ruffling your feathers a little, this matrix rotation business is but a simple mapping and yes, it's done much more easily in BASIC than in SEAL-L, you're finally seeing the light ! Smile
Best regards.
V.
12-18-2019, 06:29 AM (This post was last modified: 12-18-2019 06:36 AM by Ángel Martin.)
(12-17-2019 04:18 PM)Valentin Albillo Wrote:  Hey, "Mr. Translator", it's "beyond belief", not "beyond relief". The "r" is far from the "b" in the keyboard so that's unlikely to be a typo. Wink
Nope, in this instance I wrote exactly what I wanted to say: beyond relief with 'R"- I'm very aware of the idiom and other colloquial expressions but to me language is a fluid thing, so it'll be the day when I stop expressing in my own peculiar way - I ain't translating!
I'm not saying that I don't make my regular dose of typos of course, but this time Sauron's eye has erred his aim ;=)
à bientôt,
ÁM
PS. SEAL-L, uh? pretty clever but unorthodox ;-)
12-18-2019, 07:05 AM
Ángel, your typos are uncommon and your English is perfect Smile
