Pascal triangle to a matrix
11-22-2019, 08:45 AM
Hello
I need some help. I do not program often and when I do I have doubts.
I try to put the values of the Pascal triangle,
1 --- m1(1,1)
1 1 --- m1(2,1) m1(2,2)
1 2 1 --- m1(3,1), etc
1 3 3 1
to a matrix that I call "m1" up to "f" lines, in the following way:
EXPORT Tri_Pa(f)
LOCAL n,m;
LOCAL m1;
FOR n FROM 0 TO f DO
FOR m FROM 0 TO n DO
m1(n,m):=COMB(n,m);
But the program stops in the line "m1(n,m):=…", and says: "Invalid input".
How should I define the matrix to avoid the error?
Thanks in advance for your help
Toni
11-22-2019, 01:07 PM (This post was last modified: 11-22-2019 01:28 PM by toml_12953.)
RE: Pascal triangle to a matrix
(11-22-2019 08:45 AM)Tonig00 Wrote:  Hello
1 --- m1(1,1)
1 3 3 1
Toni
What does COMB(0,0) even mean? I don't see it as being useful.
Try this:
EXPORT Tri_Pa(f)
   LOCAL n,m;
   LOCAL m1:=makemat(0,f,f);
   FOR n FROM 1 TO f DO
      FOR m FROM 1 TO n DO
         m1(n,m):=COMB(n,m);
Tom L
I think therefore I am-Descartes
I think therefore you are-Gorgias
You're not here to think-Army Sergeant
11-22-2019, 03:57 PM
(11-22-2019 08:45 AM)Tonig00 Wrote:  But the program stops in the line "m1(n,m):=…", and says: "Invalid input".
You get an error because:
- You need to define m1 as a matrix
- Matrix indices start at 1 and not 0
So here is a working version of your program :
EXPORT Tri_Pa(f)
  LOCAL n,m;
  LOCAL m1:=[[0]];
  FOR n FROM 0 TO f-1 DO
      m1(n+1,m+1):=COMB(n,m);
Note that you can also generate the same matrix using just the MAKEMAT function:
EXPORT Tri_Pa(f)
  MAKEMAT(IFTE(I<J,0,COMB(I-1,J-1)),f,f);
11-22-2019, 07:14 PM
Thanks very much
Both works, and very interesting how the matrix works and the IFTE function.
Thanks
