Special HP50G Program for replacing " or other signs
11-05-2019, 01:34 PM
I use Android Emu 48,a great application.
I have the following HP50G program
« 100 "abc" 200 "->def"» 'P1' STO.
I want to see, in a doc like Word, the full steps of P1.
For that, I have to copy the content of P1 to (Word) doc.
Normally easily done if it were
« 100 200 » : I would change the prog into a string
"100 200" and use the Copy-to-stack of Emu48 and then Paste (Contr+V) in the (Word) doc.
With « 100 "abc" 200 "», however, the inner strings of P1 does not help and allow it ss it is.
1) First, I have to put P1 in the stack.
2) Edit it
3) Use the REPLACE command of Edit.
4) And replace all the " characters by, for example, $,
to get « 100 $abc$ 200 $->def$».
5) Then I can convert this new program into the required string "« 100 $abc$ 200 $->def$»" to use the copy-stack command of Emu48 and copy the above string in my (Word) doc.
I want a first program P.Prog->String of the kind
« EDIT...
search for sign " and replace by...
search for sign - > and replace by...
search for all special signs not taken into account during the transfer and replace them by...
(working as follows:
ENTER
P.Pring->String
EVAL or ENTER
« 100 $abc$ 200 $#def$»)
and a 2nd one, P. String->Prog. Bck, to convert back
"« 100 $abc$ 200 $#def$»" into
« 100 "abc" 200 "->def"».
Ideally, both programs should convert all the strange characters in one execution ; and better : use the prog once for all the variables in a directory.
Could somebody help me?
I thank you in advance for your valuable contribution.
Gil
11-06-2019, 08:19 PM
RE: Special HP50G Program for replacing " or other signs
Use these two programs originally by John H. Meyers.
'IN'
@ 7-bit ascii string -> calc object
\<< \->STR 3 TRANSIO RCLF SIZE 3 >
#2F34Dh #3016Bh IFTE SYSEVAL + STR\-> \>>
'OUT'
@ Calc object -> 7-bit ascii string
\<< STD 64 STWS \->STR 3 TRANSIO RCLF SIZE 3 >
#2F34Fh #2FEC9h IFTE SYSEVAL \>>
Usage: Put the object you want to export onto the stack and run OUT. This converts it to a fully-escaped string that you can cut and paste into a file on your PC. The program IN does the reverse: paste the converted string into the stack, run IN and it is converted back to an RPL object
11-15-2019, 11:47 PM
Thanks, Bruce! I had tried versions of those programs from one of John H. Meyers' posts but they didn't work on the HP 50. The ones you posted here work fine.
11-16-2019, 09:12 AM
(11-06-2019 08:19 PM)BruceH Wrote:  Use these two programs originally by John H. Meyers.
I like the way this detects whether it's being used on a 48 or a 49/50 with the size of the list sent back by RCLF Smile
If you squish the two programs together and preserve the flags and word size you get something like this:
'INOUT'
\<< RCWS RCLF \-> ws f
  \<< 3 TRANSIO DUP TYPE 2 IF == THEN
    \->STR f SIZE 3 > #2F34Dh #3016Bh IFTE SYSEVAL + STR\->
    ELSE
    STD 64 STWS \->STR f SIZE 3 > #2F34Fh #2FEC9h IFTE SYSEVAL
    END
    ws STWS f STOF
Place the object to convert on level 1 of the stack and run 'INOUT'. If the object was a string then it'll convert it to an RPL object. If not, then it'll convert it to a string.
There are only 10 types of people in this world. Those who understand binary and those who don't.
09-02-2021, 07:20 PM
INOUT: Very nice little and useful program! (I ended in this post from a previous reference from John Keith).
Ramón
Valladolid, Spain
TI-50, Casio fx-180P, HP48GX, HP50g, HP Prime G2
