12C/15C/15CP Public Beta - iOS/Android
10-24-2019, 06:14 AM
(This post was last modified: 10-31-2019 02:41 AM by Tim Wessman.)
In case you have any desire to test or play with the updated "official HP" apps for the 12C,12CP and 15C they are available - or will be shortly available - on both Android and iOS. There is basically no change from before, but they have been rebuilt for newer OS versions and things like better haptic touch, sound, etc has been done. The underlying capability and form/function did not change in any way. (I hope!) Android Here is the Opt-in URL for the following apps: 12C: https://play.google.com/apps/testing/com.hp.hp12c 12CP: https://play.google.com/apps/testing/com.hp.hp12cpt 15C: https://play.google.com/apps/testing/com.hp.hp15c15 iOS 12C: https://testflight.apple.com/join/gRYZBFYc 12CP: https://testflight.apple.com/join/aYSwG4U2 15C: https://testflight.apple.com/join/WAi4IAu5 TW Although I work for HP, the views and opinions I post here are my own. |
10-24-2019, 07:38 AM
RE: 12C/15C/15CP Public Beta - iOS/Android
For some reason I can't download any of the three apps. It says "Your account isn't currently eligible for this app's testing program". Maybe it's because I'm in Spain?
10-24-2019, 07:48 AM
Hi Tim,
Thanks, would love to try, but all links are telling me that my account is not eligible, anything I need to do ? Best regards |
10-24-2019, 10:55 AM
It doesn't seem to have anything to do with which country you're in. I'm in the U.S. and all three links take me to this message:
Quote:App not available for this account |
10-24-2019, 01:16 PM
All 3 of these apps were updated automatically on my Android phone yesterday, they just came along with other updates. But note that I HAD been on the earlier Beta test 'list' so they probably are still being treated as Beta, and limited to release only to those on the old list.
@Tim - any chance that once the Beta review has established the build process is OK, 2 old change requests could be integrated: 1. On the 12C and 12CP, on the Portrait mode layout, change the Square Root key to %, used FAR more frequently by Financial machine users. 2. 12CP emulator returns results inconsistent with hardware 12CP for some calculations. I can search and find the posts from 1-2 years ago if needed to find the specific cases found if needed. Thanks --Bob Prosperi |
10-24-2019, 03:04 PM
Hoping these bugs got worked out:
https://www.hpmuseum.org/forum/thread-402.html https://www.hpmuseum.org/forum/thread-5176.html HP 11C, 12C, 15C, DM15L, 42S, 48S, 50G, TI-89, Casio FX7000GA and a ton of slide rules. WTB: DM42 |
10-24-2019, 03:13 PM
Thanks very much, Tim.
I had the 15C app already installed, and got the update. It wouldn't turn on — blank LCD — and eventually I had to reset it, losing my programs. Not a big deal. Would you like this reporting via calcbeta, is that only for the Prime updates? Or is it just expected? Seems OK after update; will test more. === Now to talk myself into buying one or both of the 12C apps; they're quite expensive!
Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot Casio, Rockwell 18R |
10-25-2019, 02:35 AM
(10-24-2019 01:16 PM)rprosperi Wrote: [snip] Here is the thread with several examples of the 12CP Android emulator providing different results from the genuine 12CP: https://www.hpmuseum.org/forum/thread-11...#pid103736 --Bob Prosperi |
10-25-2019, 06:47 AM
I think the links should be functional now.
No, there is not any additional changes past simple recompiling on newer versions of ios/android. TW Although I work for HP, the views and opinions I post here are my own. |
10-31-2019, 02:41 AM
Added iOS links.
10-31-2019, 05:25 PM
| RE: 12C/15C/15CP Public Beta - iOS/Android | |||
11-01-2019, 10:36 AM
My displays look fine iOS on iPhone 7
11-02-2019, 08:58 AM
(10-31-2019 05:25 PM)pinkman Wrote:(10-31-2019 02:41 AM)Tim Wessman Wrote: Added iOS links. Out of curiosity, which way were you holding it when you started the app up? veritcal or horizontal? TW Although I work for HP, the views and opinions I post here are my own. |
11-02-2019, 09:37 AM
(11-02-2019 08:58 AM)Tim Wessman Wrote:(10-31-2019 05:25 PM)pinkman Wrote: Seen, installed, run. Pretty cool, but the display is incorrect (same for 15C and 12CP, did not try 12C) -> am I the only one? Ah! The infamous, Apple "you're holding it wrong!" bug.
— Ian Abbott |
11-02-2019, 11:15 AM
(11-02-2019 08:58 AM)Tim Wessman Wrote:(10-31-2019 05:25 PM)pinkman Wrote: Seen, installed, run. Pretty cool, but the display is incorrect (same for 15C and 12CP, did not try 12C) -> am I the only one? Vertically. I also tried starting it horizontally, but same behavior. iPhone XR, iOS 13.1.3. |
11-08-2019, 04:27 PM
(11-02-2019 09:37 AM)ijabbott Wrote: Ah! The infamous, Apple "you're holding it wrong!" bug. Nah, just last time I saw something like this it did have a different behavior on some phones/ios versions if the phone happened to be sideways. This one seems like only might be on the latest phones... TW Although I work for HP, the views and opinions I post here are my own. |
Search
Member List
Calendar
Help
