(EL-5100) Hemodynamic Calculations
10-23-2019, 10:36 PM (This post was last modified: 10-23-2019 11:06 PM by SlideRule.)
Letter to the Editor from ANESTHESIA AND ANALGESIA, Vol 59, No 7, July 1980 pg-519
"Hemodynamic Calculations
To the Editor:
In a recent article … {The hemodynamic tracking system: a method of data management and guide for cardiovascular therapy. Anesth Analg 59:169-174, 1980} … displayed a very useful program for simplifying the repetitive calculation of hemodynamic variables in the operating room by using a hand-held programmable calculator. They used a TI-59 calculator … As an alternative, I would like to mention a less expensive calculator which we have found useful, namely the SHARP EL-5100Although lacking the programming size and data storage, the facility of magnetic tape program insertion and the ability to perform iterative loops of the TI-59, the EL-5100 … has a LCD display with a 1000-hour battery life, is compact, has efficient program editing and correcting features, and is programmed by algebraic statements rather than machine instructions. Also, memory is preserved during power off.
To use this calculator with the format suggested … insert the following program in the AER mode:
f(ABCDEFG) = B + A, 1 Exp 3 X B +- AC, (D-F) x B + AC x 13.6, (D-G) x A +- B, (E-F) x A f B
Program insertion requires about 1 minute.
Next in the COMP mode, the calculator will interrogate the user for the values of A to G: A, body surface area (m²); B, cardiac output (L/min); C, pulse rate; D, mean systemic blood pressure (torr); E, mean pulmonary arterial pressure (torr); F, mean pulmonary capillary wedge pressure (torr); and G, mean right atrial pressure (torr). If body surface area is unknown, height (cm)°‧⁷²⁵ X weight (kg)°‧⁴²⁵ X 7.184 X 10⁻³ may be entered and the calculator will enter the calculated body surface area into memory A.
The calculator will then show five consecutive answers: ANS 1 = cardiac index (L/min/m²); ANS 2 = stroke volume index (ml/beat/m²); ANS 3 = left ventricular stroke work index (g-m/beat/m²), ANS 4 = systemic vascular resistance (resistance units), and ANS 5 = pulmonary vascular resistance (resistance units).
Nathan Leon Pace, MD
Assistant Professor
Department of Anesthesiology
University of Utah College of Medicine
The TI-59 program listing has 161 locations.
emphasis mine
BEST!
SlideRule
11-07-2019, 04:11 PM
RE: (EL-5100) Hemodynamic Calculations
(10-23-2019 10:36 PM)SlideRule Wrote:  As an alternative, I would like to mention a less expensive calculator which we have found useful, namely the SHARP EL-5100
The SHARP EL-5100 is a most awesome advanced calculator released 40 years ago (1979) and probably the most beautiful of them all in pure aesthetic grounds. I own one, which was a present from a close friend 11 years ago, and consider it unsurpassed in terms of elegance and sheer beauty, it's certainly one of the jewels in my collection.
To see a picture of mine, click here. There's also a detailed description in the SHARP Pictures section of my web site.
Regards.
V.
