(12C) Square Root
10-02-2019, 10:23 AM (This post was last modified: 10-03-2019 04:10 AM by Gamo.)
(12C) Square Root
For case study purpose here is the very interesting algorithm to compute the square root of a number
by using this equation.
B = [A+(n÷A)] ÷ 2
This equation used Successive Approximation Algorithms that continue to better approximate some desired result by providing the initial guess then this program will converge on to the correct answer if your initial guess is bad then more iteration will be required to achieve a giving accuracy.
With this program it doesn't matter where you start your initial guess because this algorithm also used the
Change in the Approximation: ABS [(B-A) ÷ A] and Tolerance of 0.00000001 to guarantee that the result will be possible.
This equation solves for B, which is the new improved approximation for the square root of n until we are happy with this approximation, we continue repeating the process by coping the new B value into A and then re-executing the same equation to get a new B value.
Procedure: FIX 8
n [ENTER] A [R/S] display Answer [X<>Y] number of iterations
Example: √10 used 3 as a guess
10 [ENTER] 3 [R/S] 3.16227766 [X<>Y] 3.00000000
Answer: √10 = 3.16227766 and program took 3 iterations to get this answer.
Program:
01 STO 2  // A
02 R↓
03 STO 1  // n
04  0
05 STO 0  // Counter
06 RCL 1
07 RCL 2
08  ÷
09 LSTx
10  +
11  2
12  ÷
13 STO 3  // Store B
14 RCL 2
15  -
16 LSTx
17  ÷
18  0
19 X<>Y
20 X≤Y
21 CHS
22 EEX
23 CHS
24  8
25 X<>Y
26 X≤Y
27 GTO 33
28 RCL 3  // B
29 STO 2  // Store A
30  1
31 STO+0
32 GTO 06
33 RCL 0
34 RCL 3
35 GTO 00
Gamo
10-02-2019, 02:36 PM (This post was last modified: 10-02-2019 02:48 PM by Albert Chan.)
RE: (12C) Square Root
It might be better not asking the user to supply a possibly bad guess.
Instead, user is limited to enter value between 0.1 to 10
For example, N=12345, user entered n=1.2345, √N = 100 √n
A naive guess = 0.5*(1+n) might create big relative errors.
Worst case at the edge, n=0.1 or 10
max_rel_err = |1 - 0.5*11/√10| ≈ 0.7393 ≈ 74%
Each iteration guaranteed to reduce max_rel_err to ½(prev_rel_err)², we got:
0.7393 → 0.2732 → 0.03733 → 0.0006968 → 2.428e-7 → 2.947e-14
Thus, a maximum of 5 iterations to reach 10 digits accuracy.
A better guess = k * (1+n), such that rel_err(n=1) = - rel_err(n=10).
In other words, |rel_error| for n = 0.1 to 10 have 3 peaks, with W shape.
XCas> simplify(solve(1-k*2/1 = k*11/sqrt(10) - 1, k))     → k = (22√10 - 40)/81 ≈ 0.365
guess = 0.365 * (1 + n) reduced max_rel_err to 27%, thus required at most 4 iterations.
Ref: Numerical Analysis by Ridgway Scott, section 1.3.2, the best start
10-03-2019, 02:01 AM (This post was last modified: 10-03-2019 04:13 AM by Gamo.)
Thanks Albert Chan
Very interesting article.
I have streamline this program a bit, now no counter, with an educated guess,
program will take on average less than 5 iterations.
This program update included Pause to observe each iterations until converge to an answer.
Program:
01 STO 2
02 R↓
03 STO 1
04 RCL 1
05 RCL 2
06  ÷
07 LSTx
08  +
09  2
10  ÷
11 PSE
12 STO 3
13 RCL 2
14  -
15 LSTx
16  ÷
17  0
18 X<>Y
19 X≤Y
20 CHS
21 EEX
22 CHS
23  8
24 X<>Y
25 X≤Y
26 GTO 30
27 RCL 3
28 STO 2
29 GTO 04
30 RCL 3
Hints:
Program line 17 to 20 is the [ABS] function with this routine we avoid using n [ENTER] [x] [√x] because
it is kind of funny to use [√x] in program while this program is looking for the Square Root. Smile
This [ABS] function routine is also work good on HP-10C I have post earlier here
https://www.hpmuseum.org/forum/thread-12138.html
Gamo
