BLAS-Prime: Basic Linear Algebra Subprograms
09-08-2019, 11:11 PM (This post was last modified: 09-09-2019 11:56 AM by StephenG1CMZ.)
I have been comparing the functionality of the common Basic Linear Algebra Subprograms and those operations built into the Prime.
In doing so, I have implemented some BLAS functions in PPL, based on the Fortran reference code that is unoptimised. Or using a built-in if obvious.
Stephen Lewkowicz (G1CMZ)
09-08-2019, 11:13 PM (This post was last modified: 09-24-2019 10:21 PM by StephenG1CMZ.)
RE: BLAS-Prime: Basic Linear Algebra Subprograms
V 0.1 implements most of BLAS Level 1 functions in single precision.
Main code:
 //CUSTOMISE
 LOCAL RABL:=1; //RETURN AS BLAS OR LIST
  //TBD:BETTER EXAMPLE
  //SET RAL TO 1: ENABLES THE BLAS-LIKE SYNTAX
    //sto(SSWAP(XX,YY),{'XX','YY'}); //XX AND YY UPDATE
    //a list of parameters can be updated
  //SET RAL:=0: USE THE PPL SYNTAX
    //RESULTS:=SSWAP(XX,YY);
    //XX:=RESULTS(1);YY:=RESULTS(2);...ETC
  LOCAL RAN:=1; //RESULT APPROXIMATE NUMERIC
   //1-(RESULT APPROX NUMERIC: DEFAULT)
   //0-(RESULT PPL EXACT WHEN AVAILABLE FROM IMPLEMENT)
 //END CUSTOM
 EXPORT ABOUT()
  PRINT();
  PRINT("BLAS-Prime V0.1 © StephenG1CMZ");
  PRINT("Based on BLAS Reference Fortran code (not optimised)");
  PRINT("http://www.netlib.org/blas/#_reference_blas_version_3_8_0");
  PRINT("This PPL implementation is not verified ");
  PRINT("V0.1: mimics BLAS Level 1");
  PRINT("No N or stride");
  PRINT("Some Givens rotations TBD");
 //PPL SUPPORT ROUTINES
 RET(PARAM)
  RETURN IFTE(RABL,{PARAM},PARAM);
EXPORT SFPINFO () //ENVIRONMENT
 EXPORT MYCONJ(VEC)
  LOCAL CNJVEC;
  //CNJVC:=list2mat(conj(mat2list(VEC)));
  LOCAL LVEC:=mat2list(VEC);
  LOCAL LCNJVEC:=(RE(LVEC)-IM(LVEC)*);//CONJ NEGATES IM
  CNJVEC:=list2mat(LCNJVEC,SIZE(LCNJVEC));
  //PRINT("CNJ: "+CNJVEC);
  RETURN CNJVEC(1);//AN ARTIFACT OF SYNTAX ON VECTORS
 //BLAS
 EXPORT BLAS_L1_vector() //HEADING
 //BLAS LEVEL 1 VECTOR OPERATIONS
 //Complex Single
 //CROTG - setup Givens rotation
 EXPORT CSROTGTBD()
 //CSROT - apply Givens rotation
 EXPORT CSROTTBD()
 //CSWAP - swap x and y
 EXPORT CSWAP(VECX,VECY)
 //call: sto(SSWAP(XX,YY),{'XX','YY'});
  RETURN {VECY,VECX};//IDENTICAL
 //CSCAL - x = a*x
 EXPORT CSCAL(SCL,VECX)    //   SUBROUTINE CSCAL(N,CA,CX,INCX)
 //*>    CSCAL scales a vector by a constant.
 //*> \param[in] N
 //*> \param[in] CA       CA is COMPLEX
 //*> \param[in,out] CX  CX Is COMPLEX array, dimension ( 1 + ( N - 1 )*abs( INCX ) )
  RET  (SCL*VECX);//IDENTICAL
 //CSSCAL - x = a*x
 EXPORT CSSCAL(SCL,VECX)     //  SUBROUTINE CSSCAL(N,SA,CX,INCX)
 //*>    CSSCAL scales a complex vector by a real constant.
 //*> \param[in] N
 //*> \param[in] SA         SA is REAL
 //*> \param[in,out] CX     CX is COMPLEX array, dimension ( 1 + ( N - 1 )*abs( INCX ) )
 //CCOPY - copy x into y
 EXPORT CCOPY(VECX,VECY)   //    SUBROUTINE CCOPY(N,CX,INCX,CY,INCY)
 //*>    CCOPY copies a vector x to a vector y.
 //*> \param[in] N
 //*> \param[in] CX    CX is COMPLEX array, dimension ( 1 + ( N - 1 )*abs( INCX ) )
 //*> \param[out] CY   CY is COMPLEX array, dimension ( 1 + ( N - 1 )*abs( INCY ) )
 //NOTE:MY IMPLEMENT CURRENTLY REPLACES Y BY X (LEAVING IT SHORTER WHEN SIZE(X)<SIZE(Y))
  RET (VECX);
 //CAXPY - y = a*x + y
 EXPORT CAXPY(SCL,VECX,VECY)    //   SUBROUTINE CAXPY(N,CA,CX,INCX,CY,INCY)
 //*>    CAXPY constant times a vector plus a vector.
 //*> \param[in] N
 //*>           On entry, CA specifies the scalar alpha.
 //*> \param[in,out] CY   CY is COMPLEX array, dimension ( 1 + ( N - 1 )*abs( INCY ) )
  RETURN {(SCL*VECX+VECY)};//IDENTICAL
 //CDOTU - dot product
 EXPORT CDOTU(VECX,VECY)    //   COMPLEX FUNCTION CDOTU(N,CX,INCX,CY,INCY)
 //      COMPLEX CX(*),CY(*)
 //*> CDOTU forms the dot product of two complex vectors
 //*>      CDOTU = X^T * Y
 //*> \param[in] CX    CX is REAL array, dimension ( 1 + ( N - 1 )*abs( INCX ) )
 //*> \param[in] CY    CY is REAL array, dimension ( 1 + ( N - 1 )*abs( INCY ) )
  //LOCAL II;
  //LOCAL CTMP:=0;
  //LOCAL DIMX:=DIM(VECX);
  //LOCAL DIMY:=DIM(VECY);
  //LOCAL NNN:=MIN({DIMX(1),DIMX(1)});
  //MSGBOX(DIM(VECX));
  //FOR II:=1 TO NNN DO
  // CTMP:=CTMP+VECX(II)*VECY(II);
  //END;
  //RETURN CTMP;
  RETURN dot(VECX,VECY);//IDENTICAL
 //CDOTC - dot product, conjugating the first vector
 EXPORT CDOTC(VECX,VECY)   //    COMPLEX FUNCTION CDOTC(N,CX,INCX,CY,INCY)
 //*       COMPLEX CX(*),CY(*)
 //*> CDOTC forms the dot product of two complex vectors
 //*>      CDOTC = X^H * Y
  //PRINT({VECX,VECY});
  //PRINT({MYCONJ(VECX),VECY});
  RETURN CDOTU(MYCONJ(VECX),VECY);
 //SCASUM - sum of absolute values
 EXPORT SCASUM(VEC) //  REAL FUNCTION SCASUM(N,CX,INCX)
 //*>    SCASUM takes the sum of the (|Re(.)| + |Im(.)|)'s of a complex vector and
 //*>    returns a single precision result.
 //Query: CX is inout but unchanged
 //sum(abs) re and im separately
  //RETURN SASUM(RE(mat2list(VEC)))+SASUM(IM(mat2list(VEC)))*;
  RETURN CAS.l1norm(VEC);
  //RETURN SASUM(VEC);//IDENTICAL
 //ICAMAX - index of max abs value
 EXPORT ICAMAX(VC)
 LOCAL STRIDE:=1;
 //ICAMAX and IZAMAX find the first element xk, where k is defined as the smallest index k, such that:
 //|ak|+|bk| = max{|aj|+|bj| for j = 1, n}
 //where xk = (ak, bk)
 //By specifying a positive or negative stride for vector x, the first or last occurrence, respectively, is found in the array. The position i, returned as the value of the function, is always figured relative to the location specified in the calling sequence for vector x (in argument x). Therefore, depending on the stride specified for incx, i has the following values:
 //For incx ≥ 0, i = k
 //For incx < 0, i = n-k+1
  LOCAL LVC:=mat2list(VC);
  LOCAL LBOTH:=ABS(RE(LVC))+ABS(IM(LVC));
  //IF STRIDE<0 THEN NONSTANDARD
  // RETURN ICAMAX(list2mat(REVERSE(LVC)),−STRIDE);//TBD
  //END;
  IF STRIDE>1 THEN
   //TBD;
  RETURN POS(LBOTH,MAX(LBOTH));
 //Real Single
 //SROTG - setup Givens rotation
 EXPORT SROTGTBD(SA,SB) // SUBROUTINE SROTG(SA,SB,C,S)*     .. Scalar Arguments ..
 //REAL C,S,SA,SB
  LOCAL CC,SS;
  MSGBOX("TBD");
  RETURN {CC,SS};
 //SROTMG - setup modified Givens rotation
 EXPORT SROTMGTBD(SD1,SD2,SX1,SY1) //       SUBROUTINE SROTMG(SD1,SD2,SX1,SY1,SPARAM)
 //*> \param[in,out] SD1  SD1 is REAL
 //*> \param[in,out] SD2  SD2 is REAL
 //*> \param[in,out] SX1  SX1 is REAL
 //*> \param[in]     SY1  SY1 is REAL
 //*> \param[out] SPARAM  SPARAM is REAL array, dimension (5)
  //*>     SPARAM(1)=SFLAG
  //*>     SPARAM(2)=SH11
  //*>     SPARAM(3)=SH21
  //*>     SPARAM(4)=SH12
  //*>     SPARAM(5)=SH22
  LOCAL SD1OUT,SD2OUT,SX1OUT;
  LOCAL PARAM:={};
  MSGBOX("TBD");
  RETURN {SD1OUT,SD2OUT,SX1OUT,PARAM};
 //SROT - apply Givens rotation
 EXPORT SROTTBD(VECSX,VECSY,CC,SS) //SUBROUTINE SROT(N,SX,INCX,SY,INCY,C,S)
 //*> \param[in,out] SX   SX is REAL array, dimension ( 1 + ( N - 1 )*abs( INCX )
 //*> \param[in]     INCX INCX is INTEGER
 //*> \param[in,out] SY   SY is REAL array, dimension ( 1 + ( N - 1 )*abs( INCY ) )
 //*> \param[in]     INCY INCY is INTEGER
 //*> \param[in]     C    C is REAL
 //*> \param[in]     S    S is REAL
  LOCAL SX,SY;
  MSGBOX("TBD");
  RETURN {SX,SY};
 //SROTM - apply modified Givens rotation
 EXPORT SROTMTBD(VECSX,VECSY,SPARAM) //SUBROUTINE SROTM(N,SX,INCX,SY,INCY,SPARAM)
 //*> \param[in]       N   N is INTEGER
 //*>         number of elements in input vector
 //*> \param[in]  SPARAM  SPARAM is REAL array, dimension (5)
  //*>     SPARAM(2)=SH11
  //*>     SPARAM(3)=SH21
  //*>     SPARAM(4)=SH12
  //*>     SPARAM(5)=SH22
  LOCAL SX,SY;
  RETURN {SX,SY};
 //SSWAP - swap x and y
 EXPORT SSWAP(VECX,VECY) //   SUBROUTINE SSWAP(N,SX,INCX,SY,INCY)
 //SSCAL - x = a*x
 EXPORT SSCAL(SCL,VEC) //SUBROUTINE SSCAL(N,SA,SX,INCX)
 //call: sto(SSCAL(SCL,VEC),{'VEC'});
  RET (SCL*VEC);//IDENTICAL
 //SCOPY - copy x into y
 EXPORT SCOPY(VECX,VECY) // SUBROUTINE SCOPY(N,SX,INCX,SY,INCY)
  RET (VECX);//IDENTICAL
 //SAXPY - y = a*x + y //const*VEC+VEC
 EXPORT SAXPY(SCL,VECX,VECY) // SUBROUTINE SAXPY(N,SA,SX,INCX,SY,INCY)
  RETURN CAXPY(SCL,VECX,VECY);//IDENTICAL (ASSUMING REAL VECS)
  //RETURN {(SCL*VECX+VECY)};//IDENTICAL
 //SDOT - dot product //of 2 vectors
 EXPORT SDOT(VECX,VECY) // REAL SDOT(N,SX,INCX,SY,INCY)
  RETURN CDOTU(VECX,VECY);//IDENTICAL (ASSUMING VECS ARE REAL)
  //RETURN dot(VECX,VECY);//IDENTICAL
 //SDSDOT - dot product with extended precision accumulation
 EXPORT SDSDOT(SB,VECX,VECY) //REAL FUNCTION SDSDOT(N,SB,SX,INCX,SY,INCY)
 //THE ORIGINAL FORTRAN IMPLEMENTS DOT USING DOUBLES TO IMPROVE PRECISION
 //PPL: NO EXTENDED PRECISION (iust making parameters of dot exact doesnt help)
  RETURN SB+SDOT(VECX,VECY);
 //SNRM2 - Euclidean norm
 EXPORT SNRM2(VECX) //REAL FUNCTION SNRM2(N,X,INCX)
  LOCAL EUC:=CAS.l2norm(VECX);
  RETURN IFTE(RAN,approx(EUC),EUC);
 //These currently return exact if RAN=0
 //SCNRM2- Euclidean norm of complex
 EXPORT SCNRM2(CVECX)
  LOCAL EUC:=CAS.l2norm(CVECX);
 //SASUM - sum of absolute values
 EXPORT SASUM(VEC) //       REAL FUNCTION SASUM(N,SX,INCX)
  //RETURN ΣLIST(ABS(mat2list(VEC)));
  //RETURN CSASUM(VEC);//IDENTICAL
 //ISAMAX - index of max abs value
 EXPORT ISAMAX(VEC) //INTEGER FUNCTION ISAMAX(N,SX,INCX)
 //INDEX OF MAX ABS REAL
 //INDEX OF MAX ABS (REALPART+IMPART) Z
 //NB THE CODE IS OPTIMISED ASSUMING REAL.
 //IT WILL GIVE DIFFERENT RESULTS THAN ICAMAX IF GIVEN COMPLEX.
 //IF YOU WANT IDENTICAL RESULTS CALL ICAMAX
  LOCAL STRIDE:=1;
  LOCAL LVC:=mat2list(VEC);
  LOCAL LBOTH:=ABS(LVC);//OPTIMISED FOR REAL.
  //ABS(RE(LVC))+ABS(IM(LVC));//COMPLEX
  //END;
  IF STRIDE>1 THEN
   //TBD;
  //RETURN ICAMAX(VEC);//UNOPTIMISED
 //EXTRAS: NOT BLAS STANDARD
 //REAL SINGLE
 EXPORT ISMAX (VC)
 //INDEX MAXIMUM (CF ISAMAX)
 //OK REAL
  LOCAL MX:=MAX(LVC);
  RETURN POS(LVC,MX);
 EXPORT ISMIN (VC)
 //INDEX MINIMUM (CF ISMAX ISAMAX)
 //OK REAL
  LOCAL MN:=MIN(LVC);
  RETURN POS(LVC,MN);
 EXPORT BLAS()
  //PPL TYPE DOES NOT DISTINGUISH VECTORS AND MATRICES
  //PRINT(TYPE([1]));
  //PRINT(TYPE([[1],[2]]));
Some Givens rotations:
 EXPORT CABS(NUM)
 //FTN COMPLEX ABS
  RETURN ABS(NUM);
  //RETURN SQRT(RE(NUM)^2+IM(NUM)^2);
 EXPORT SIGNFTN(AA,BB)
 //FTN COPYSIGN RETURNS SGN(BB)*AA
 //IF B ZERO ABS(A)
 //RETURN {1,0,−1} (SOME IMPLEMENTS ALLOW −0 RETURN)
  RETURN IFTE(BB<0,-ABS(AA),ABS(AA));
 EXPORT COPYSIGN(AVALUE,ASIGN)
  RETURN IFTE(ASIGN<0,-ABS(AVALUE),ABS(AVALUE));
  //RETURN SIGNFTN(AVALUE,ASIGN);
 EXPORT CONJG(ZZ)
 //CONJUGATE OF A COMPLEX NUMBER
 //FTN
  RETURN RE(ZZ)-IM(ZZ)*;
 EXPORT CROTG(CXA,CXB) // *       SUBROUTINE CROTG(CA,CB,C,S)
 //*       COMPLEX CA,CB,S
 //*       REAL C
 //CROTG determines a complex Givens rotation.
 //*> \param[in] CB       CB is COMPLEX
 //*> \param[out] C        C is REAL
 //*> \param[out] S        S is COMPLEX
 //call: sto(CROTG(AA,BB),{'AA','BB','CC','SS'})
  LOCAL CA:=CXA; //LOCAL CB:=CXB;//INOUTS
  LOCAL CC,SS;
    // COMPLEX SS
    // REAL CC
   //*     .. Local Scalars ..
   LOCAL ALPHA; //COMPLEX
   LOCAL NORM,SCALE; //REAL
   //*     .. Intrinsic Functions ..
   //    INTRINSIC CABS,CONJG,SQRT
    //PRINT({"CROTG IN:",CA,CXB});
      IF (CABS(CA)==0.) THEN
         CC:= 0.;
         SS:= 1.0; //(1.,0.);
         CA:= CXB;
      ELSE
         SCALE:= CABS(CA) + CABS(CXB);
         //SCALE:=1;//SIMPLER
         NORM:= SCALE*SQRT((CABS(CA/SCALE))^2+ (CABS(CXB/SCALE))^2);
         ALPHA:= CA/CABS(CA);
         CC:= CABS(CA)/NORM;
         SS:= ALPHA*CONJG(CXB)/NORM;
         CA:= ALPHA*NORM;
      END;//IF;
      //RETURN ROUND({CA,CC,SS},2);//SIMPLER VALUES IN TESTS
      RETURN {CA,CC,SS}; //RETURN 2 COMPLEXES AND CC REAL? (CB UNCHANGED)
 EXPORT CSROT(VECX,VECY,CS,SN) //       SUBROUTINE CSROT( N, CX, INCX, CY, INCY, CS, SN)
 //*       .. Scalar Arguments ..
 //*       INTEGER           INCX, INCY, N
 //*       REAL              CS, SN
 //*       .. Array Arguments ..
 //*       COMPLEX           CX( * ), CY( * )
 //*> CSROT applies a plane rotation, where the cos and sin (c and s) are real
 //*> and the vectors cx and cy are complex.
 //*> \param[in] CS         CS is REAL
 //*>           On entry, C specifies the cosine, cos.
 //*> \param[in] SN         SN is REAL
  LOCAL VECXOUT,VECYOUT;
  VECXOUT:=CS*VECX+SN*VECY;
  VECYOUT:=CS*VECY-SN*VECX;
  RETURN ROUND({VECXOUT,VECYOUT},3);//TESTS
  RETURN {VECXOUT,VECYOUT};
 EXPORT SROTG(SA,SB) //  SUBROUTINE SROTG(SA,SB,C,S)
 //  REAL C,S,SA,SB
 //*>          SA is REAL
 //*>          SB is REAL
 //*> \param[out] S     S is REAL
 //call: sto(SROTG(AA,BB),{'AA','BB','CC','SS'})
 //*>    SROTG construct givens plane rotation.
 //A real Givens plane rotation is constructed for values a and b by computing values for r, c, s, and z, where:
 //Real Givens Plane Rotation Math Graphic
  LOCAL RR,ROE,SCALE,ZZ;
  LOCAL CC;
  LOCAL SS;
      ROE:=IFTE(ABS(SA)>ABS(SB),SA,SB);
      SCALE:= ABS(SA) + ABS(SB);//AVOID LOP
      IF (SCALE==0.0) THEN
         CC:= 1.0;
         SS:= 0.0;
         RR:= 0.0;
         ZZ:= 0.0;
      ELSE
         RR:=SCALE*SQRT((SA/SCALE)^2+ (SB/SCALE)^2); //AVOID LOP
          //FTN:SCALING TO AVOID LOP
          //PPL:EXAMPLES BETTER WITHOUT (ALT. ROUND OUTPUTS)
         //RR:=SQRT((SA)^2+ (SB)^2);
         RR:=COPYSIGN(1.0,ROE)*RR; //COPYSIGN
         //RR:=SIGN(ROE)*RR;
         CC:= SA/RR;
         SS:= SB/RR;
         ZZ:= 1.0;
         IF (ABS(SA)>ABS(SB)) THEN ZZ:= SS; END;
         IF (ABS(SB)≥ABS(SA) AND CC≠0.0) THEN ZZ:= 1.0/CC; END;
      END;// IF
      //SA := RR;//RR AND ZZ EXPECTED TO REPLACE SA SB
      //SB := ZZ;
      //RETURN ROUND({RR,ZZ,CC,SS},3);//SIMPLER VALUES IN TESTS
      RETURN {RR,ZZ,CC,SS}; //RETURN 4 REALS
 EXPORT EXGIVENS()
  LOCAL CS:=0.5;
  LOCAL SN:=(√(3.0))/2.0;
  PRINT();
  PRINT({SROTG(0.0,0.0),"=",{0,0,1,0}});
  PRINT({SROTG(0.0,2.0),"=",{2,1,0,1}});
  PRINT({SROTG(6.0,−8.0),"=",{−10,−1.667,−0.6,0.8}});
  PRINT({SROTG(8.0,6.0),"=",{10,0.6,0.8,0.6}});
  PRINT({CROTG(0.0,1.0),"=", "A=(1.0, 0.0) C =  0.0 S =  (1.0, 0.0)"});
  PRINT({CROTG((3.0+ 4.0*),(4.0+6.0*)),"=", "  A =  (5.26, 7.02) C  =  0.57 S  =  (0.82, -0.05) "});
  PRINT({CSROT([(1.0+ 2.0*),(2.0+ 3.0*), (3.0+ 4.0*)],[(-1.0+ 5.0*),(-2.0+ 4.0*),(-3.0+ 3.0*)],CS,SN)});
  PRINT({"=","X=((-0.366, 5.330), (-0.732, 4.964), (-1.098, 4.598))
Y=((-1.366, 0.768),(-2.732, -0.598),(-4.098, -1.964))"})
 EXPORT GIVENS()
  //A VECTOR MUST BE <20000
  //BUT SOME ROUTINES USE MATLIST SO 10000
  LOCAL CS:=0.5;
  LOCAL SN:=(√3)/2;
  LOCAL VECX:=MAKEMAT(10*J/1000,1000);
  LOCAL VECY:=MAKEMAT(10*J/1000,1000);
  PRINT();
  PRINT("GO "+DIM(VECX));
  PRINT({TEVAL(CROTG((3.0+ 4.0*),(4.0+6.0*)))});
  PRINT({TEVAL(CSROT(VECX,VECY,CS,SN))});
Vectors in PPL can have 20 000-1 elements, but some functions are implemented using mat2list, and lists only have 10 000 elements. There is currently no error checking.
Note: Some functions may round results. This is simply for clarity in displaying test results.
