(12C Platinum) Parabola - arc length
06-29-2019, 10:22 AM (This post was last modified: 07-02-2019 12:30 AM by Gamo.)
The Arc Length of a Parabola calculator compute the arc length (S)
of a parabola based on the distance height (H) and
the width (L) of the parabola at that point perpendicular to the axis.
The formula for determining the length of an arc of a Parabola.
Instruction: FIX 4
1. H [R/S] display Height
2. L [R/S] display Answer of the Arc Length of a Parabola
Example: H is 20 feet and L is 90 feet, what is the length of S?
20 [R/S] display 20.000
90 [R/S] display 100.7376
Answer: 100.7376 feet
To check answer for difference problem or check if this program give
correct answer.
URL: https://www.vcalc.com/wiki/vCalc/Parabola+-+arc+length
Program: ALG mode
[÷] [R/S] [STO] 0 [=] [STO] 1
[X^2] [+] 16 [1/x] [=] [√x] [+] [(] [(] 1 [÷] [(] 16 [x] [RCL] 1 [)] [)] [x]
[(] [(] [RCL] 1 [+] [(] [RCL] 1 [X^2] [+] 16 [1/x] [)] [√x] [)] [LN] [+]
4 [LN] [)] [)] [)] [x] 2 [x] [RCL] 0 [=]  // 51 program steps //
Gamo
06-30-2019, 08:33 AM
RE: (12C Platinum) Parabola - arc length
Here is a rpl solution for the HP11C :
LBL A
STO 0
STO 1
ENTER
X2
1
6
1/x
√x
STO 2
RCL 1
4
LN
1
6
RCL 1
RCL 2
RCL 0
2
R/S //// 29 steps
Instructions : H [enter] L [A]
Dominique
06-30-2019, 11:35 AM (This post was last modified: 06-30-2019 11:38 AM by Gamo.)
Parabola -arc Length program in RPN mode using this formula:
Instruction:
H [ENTER] L [R/S] display Answer of Parabola arc length
H is the Height
L is the distance from both end
Example: FIX 4
20 [ENTER] 90 [R/S] display 100.7376
Program: RPN mode (For HP-12C replace [X^2] to [ENTER] [x]
001 STO 1
002 R↓
003 STO 0
004 X^2
005  1
006  6
007  x
008 RCL 1
009 X^2
010  +
011  √x
012 STO 2
013 RCL 0
014  4
015  x
016  +
017 RCL 1
018  ÷
019 LN
020 RCL 1
021 X^2
022 RCL 0
023  8
024  x
025  ÷
026  x
027 RCL 2
028  2
029  ÷
030  +
Gamo
07-01-2019, 09:12 AM
Thanks Dominique
Here is another version without using any STO registers and only use the stacks.
This can be adapted to HP-11C as well.
Procedure is the same: H [ENTER] L [R/S] display Parabola Arc Length
Program for HP-12C Platinum on RPN mode
001  ÷
002 LSTx
003 X<>Y
004 ENTER
005 X^2
006  1
007  6
008 1/x
009  +
010 √x
011 X<>Y
012  +
013 LSTx
014 X<>Y
015 LN
016  4
017 LN
018  +
019 X<>Y
020  1
021  6
022 X<>Y
023  x
024 LSTx
025 X<>Y
026 1/x
027 X<>Y
028 R↓
029  x
030 R↓
031 R↓
032 R↓
033 X^2
034  1
035  6
036 1/x
037  +
038 √x
039  +
040  x
041  2
042  x
Gamo
07-02-2019, 09:18 AM
(06-29-2019 10:22 AM)Gamo Wrote:  The Arc Length of a Parabola calculator compute the arc length (S)
Instruction: FIX 4
correct answer.
Program: ALG mode
Gamo
The formula given in your image can be optimised, unless LN is a natural log.
It includes two instances of LN: LN4 and LN().
Where N = H/L
Thus LN 4 can be optimised to LH/L = H, and similarly for LN() if that is an implied multiply and not a natural logarithm.
Stephen Lewkowicz (G1CMZ)
07-03-2019, 07:35 AM
This the trap ! In the formula, LN is the neperian logarithm, and not LxN !
However, you can optimize the computation : the steps sequence "ln 4 ln +" can be replace with "4 * ln".
Dominique
07-03-2019, 08:14 AM
Hello, thanks to StephenG1CMZ and Dominique
Yes Post#1 Formula look very tricky and thanks for the head up on that formula.
On Post#3 that formula is a good one to use.
Thanks
Gamo
07-03-2019, 10:07 PM
One more parameter can be calculated with the same data, the Surface:
A= 2/3 * H * L
For H= 20 and L= 90, A= 1200.00
You only need to store H in R3 and actívate LBL B with the following sequence:
LBL B
2
ENTER
3
RCL 0
RCL 3
x
x
RTN
Pedro
07-11-2019, 04:19 PM (This post was last modified: 07-11-2019 04:37 PM by Albert Chan.)
For HP-11C, code can be shortened using identity: asinh(x) = ln(x + √(x^2+1))
parabola arc length = (asinh(x)/x + √(x^2+1)) * L/2, where x=4H/L
Doing everything on the stacks, we have:
01 LBL A ; Instructions : H [enter] L [A]
02 /
03 LST-X
04 X<>Y
05 4
06 x ; x = 4H/L
07 ASINH
08 LST-X
09 /
10 LST-X
11 X^2
12 1
13 +
14 SQRT
15 +
16 x
17 2
18 /
19 R/S
