(HP-67) Particle Physics programs
06-18-2019, 08:15 PM
An extract from Some Calculator Programs for Particle Physics, U.S.DoE, UoC (Lawrence Berkeley Laboratory), LBL--13987, January 1982 (27 pgs.)
… The write-up for each program tells what the program does and how to run it, discusses any limitations or special cases or pitfalls, and gives an example or two to test that the program is stored properly and that its operation is understood. The examples have all been rechecked from the final typescript on an HP-97 … … LEGENDRE The LEGENDRE program calculates the values of the Legendre polynomial series … … ASSOCIATED LEGENDRE The ASSOCIATED LEGENDRE program calculates the values of the first-associated Legendre polynomial series … … CONFIDENCE and EVEN N and POISSON The CONFIDENCE program calculates confidence levels for the x 2 probability distribution with N degrees of freedom. The calculation is much shorter when N is even than when it is odd, so there is a short program, EVEN N, for that case (CONFIDENCE handles any N ). CONFIDENCE may also be used to get confidence levels for the Gaussian (or normal) and the Poisson probability distributions, but for the Poisson case there is a much shorter program, POISSON … … TWO BODY and CM In the 2-body reaction a + b → 1 + 2, let m(i) be the mass of particle i and let P be the momentum of particle a in the inertial frame in which particle b is at rest (the lab frame). The four masses and P are the input data for the TWO BODY program … … Program: ELLIPSE … … DALITZ RECTANGULAR The DALITZ RECTANGULAR program calculates coordinates of points on the boundary of the rectangular Dalitz plot for the decay of a particle or system of mass M into three particles having masses … … DALITZ TRIANGULAR The DALITZ TRIANGULAR program calculates coordinates of points on the boundary of the normalized triangular Dalitz plot for the decay of a particle or system of mass M into three particles having masses … BEST! SlideRule |
06-19-2019, 02:16 PM
(This post was last modified: 06-20-2019 12:55 PM by StephenG1CMZ.)
RE: (HP-67) Particle Physics programs
I wonder whether you can explain page 18 (between pages 17 and 19), which looks like the title page of another interesting document - Except that if it is a title page, it begins "registers;...".
It looks to me like a photocopying/scanning error somewhere...Except that the version for another calculator also has this page 18 and "registers;" on page 20. Stephen Lewkowicz (G1CMZ) ANDROID HP Prime App broken offline on some mobiles |
