(15C) Hydrometric Calculations (Portuguese)
06-12-2019, 12:48 PM (This post was last modified: 06-13-2019 09:12 PM by SlideRule.)
An extract from Programas para Cálculos Hidrométricos,
para Calculadora HP & TI • Microcomputadores SHARP & CASI0, CONVENIO DNAEE / CNPq / ORSTON, 1986 (134 pgs.)
HYDROMETRIC CALCULATIONS
BEST!
SlideRule
06-12-2019, 02:50 PM
RE: (15C) Hydrometric Calculations (in Spanish)
(06-12-2019 12:48 PM)SlideRule Wrote:  Send me a Spanish-English translation via PM & I'll add to the post.
This 134-page document isn't in Spanish, it's in Galizian.
V.
06-12-2019, 03:27 PM
Maybe this example helps?
.pdf  15C example.pdf (Size: 31.37 KB / Downloads: 11)
BEST!
SlideRule
06-12-2019, 08:30 PM
(06-12-2019 03:27 PM)SlideRule Wrote:  Maybe this example helps?
Still in Galizian, not Spanish. You'd need a Galizian-speaking translator.
V.
06-12-2019, 09:50 PM
V.
It sounded so close to Portuguese to me, that I pasted some text into Google Translate, and it detected it as Portuguese. I am not neither a Galician, nor a Portuguese speaker to come to a conclusion.
Saludos Saluti Cordialement Cumprimentos MfG BR + + + + +
Luigi Vampa +
Free42 HuaweiP10 '<3' I + + +
06-12-2019, 10:38 PM (This post was last modified: 06-13-2019 12:35 AM by SlideRule.)
I also went by GOOGLE TRANSLATE, my results - according to google -
main thing is there any interest in a 'minor' but correct translation of content? Any volunteers?
BEST!
SlideRule
ps: extract from https://www.britannica.com/topic/Spanish-language
"Galician (a language with many similarities to Portuguese), spoken in northwestern Spain
06-12-2019, 10:49 PM
(06-12-2019 10:38 PM)SlideRule Wrote:  I also went by GOOGLE TRANSLATE, my results - according to google -
That precise text ("Programas para Cálculos Hidrométricos") in your attached image is in Spanish.
The remaining 130+ pages of text are not, I think they're in Galizian, that indeed resembles Portuguese a lot but it's not, there are differences which might be important in a technical document (or not).
Not being either a Galizian- or Portuguese-speaker I can't tell (though I can read and mostly understand both if written or spoken).
Nothing more to add for this subject, wish you luck in finding an adequate translator.
V.
06-13-2019, 07:58 PM (This post was last modified: 06-14-2019 04:54 PM by Luigi Vampa.)
RE: (15C) Hydrometric Calculations (Romance language)
@SlideRule
I am afraid the document's tittle "Programas para cálculos hidrométricos" is written with the very same wording either in Galizian, in Portuguese... or in Spanish. It isn't a rare situation, since they are romance languages that grew up literally together in the Iberian peninsula.
THE FIRST CLUE: the first pages mention local authorities that have nothing to do with Galizian region, in Spain.
THE SECOND CLUE: the main editor's name... he has a 100% Portuguese name, he is not Galizian at all.
THE THIRD CLUE: São Paulo, Brazil, is mentioned.
So my guess, once again... Portuguese. AFAIK, there are some differences between Brazilian Portuguese and "European" Portuguese, but those should be minor in technical documents, I guess.
I can't properly speak Portuguese, but I travel to Portugal on a regular basis due to my work, and I start mixing some Portuguese vocabulary with my Español (Spanish)... ending up in what is colloquially called "Portuñol" >D
Luigi Vampa +
06-13-2019, 09:10 PM
Luigi
Thanks for the refined analysis. My only European language is Deutsche; so, Portuguese it is!
Best!
SlideRule
