(50g) Delannoy numbers
06-02-2019, 11:34 PM (This post was last modified: 06-02-2019 11:38 PM by John Keith.)
Delannoy numbers have many applications in combinatorics and number theory. Fortunately they are fast and easy to compute. Further details here.
The following program returns a rectangular array of Delannoy numbers. Given two integers referred to as m and n in the linked article, the program will return an array of m columns and n rows. The program actually returns a list of lists, and may be followed by AXL if a matrix is desired. The program requires the GoferLists library.
\<< \-> m n
  \<< 1 m NDUPN \->LIST 2 n
    START DUP 2.
      \>> DOSUBS 1
      \>> Scanl
    NEXT n \->LIST
The next program returns the Delannoy triangle, also known as the tribonacci triangle. The numbers are the same as in the array but arranged in a triangle. Given an integer n, the program returns rows 0 through n of the triangle as a list of lists.
\<< \-> n
  \<< { 1 } DUP 1 + 2 n
    START DUP2 2.
      \>> DOSUBS ADD 1 + 1 SWAP +
    NEXT n 1 + \->LIST
Finally, a program that computes the central Delannoy numbers which are the central column of the triangle and the main diagonal of the array. Given an integer n the program returns terms 0 through n of the sequence.
\<< \-> n
  \<< 1 3 2 n
    FOR k DUP2 k 6 * 3 - * SWAP k 1 - * - k /
    NEXT n 1 + \->LIST
The last two programs will run on the HP-48G but are of limited usefulness since the numbers involved grow rapidly beyond 12 digits.
06-03-2019, 06:52 PM
RE: (50g) Delannoy numbers
I never heard of Delannoy numbers. Thanks for sharing John.
Saludos Saluti Cordialement Cumprimentos MfG BR + + + + +
Luigi Vampa +
Free42 HuaweiP10 '<3' I + + +
