HP 9100A Benchmarks update for HP48G/GX Saturn assembly
05-19-2019, 04:12 PM (This post was last modified: 05-19-2019 04:48 PM by Jonathan Busby.)
Here is the the HP48G/GX-R Saturn assembly code for the HP Museum benchmarks page. All of the code, source and other files needed to build the source are included in the attached archive. The binaries are also included. Note that although the binaries are for the HP48G/GX-R, I believe that the code can be re-built for the HP48S/SX, HP49G and HP50G with about the only thing needing changing being the unsupported entries points header file.
( EDIT #1 : Note that the evolution of this code can be found in this thread and the final version here. )
Jonathan
Attached File(s)
.zip  HP-Museum-9100A-benchmarks-v0.2.3-a.zip (Size: 7.5 KB / Downloads: 13)
Aeternitas modo est. Longa non est, paene nil.
