Sum Bug
04-29-2019, 11:19 PM
Sum Bug
Hi there, I was trying Sum(x^2, x=0 to 100,000) in the Cas mode but the calculator restarts. Am I doing something wrong? It works well in home mode as well in a Ti Nspire CAS. Hopefully it is a simple bug to be fixed in the next firmware release. Thanks
04-30-2019, 01:05 AM
RE: Sum Bug
Just tested on what I think is the latest public with a Prime G1 and worked fine. Anyone else?
TW
04-30-2019, 02:26 AM
RE: Sum Bug
(04-30-2019 01:05 AM)Tim Wessman Wrote:  Just tested on what I think is the latest public with a Prime G1 and worked fine. Anyone else?
It SEEMS to hang on a rev C hardware running firmware rev 12214 (2017 08 03), but it actually finishes correctly after 24 seconds. On a rev C hardware running firmware rev 14055 (2018 09 07), it finishes almost instantly. HW rev D *does* finish instantly.
Eduardo: What is your Prime's firmware version?
<0|ΙΈ|0>
-Joe-
04-30-2019, 03:21 AM
RE: Sum Bug
On my G2 it gives an answer immediately.
Tom L
Tom L
...other than that, Mrs. Lincoln, what did you think of the play?
04-30-2019, 11:45 AM
RE: Sum Bug
Thanks so much, fixed after updating to the latest firmware.
