integrales de funciones trigonometricas hiperbolicas
04-16-2019, 09:13 PM
I recently tried to calculate an integral with hyperbolic trigonometric functions and I got the result wrong, please notify me of this to hp to solve it in the next firmware update, so I think I only think that the tanh (x), the sinh ( x) and the cosh (x) are fine, I do not know if more things fail[/size][/font]
04-17-2019, 04:18 AM
RE: integrales de funciones trigonometricas hiperbolicas
Please indicate which specific integral gave you the wrong result.
04-17-2019, 04:28 AM
I suspect "wrong result" will simply be "not in the form I think it should be", but we shall see...
Unless you provide your input, and expected output. Nobody can help in any way.
TW
04-17-2019, 06:17 AM
(04-16-2019 09:13 PM)eduardo_MO0@hotmail.com Wrote:  I recently tried to calculate an integral with hyperbolic trigonometric functions and I got the result wrong, please notify me of this to hp to solve it in the next firmware update, so I think I only think that the tanh (x), the sinh ( x) and the cosh (x) are fine, I do not know if more things fail[/size][/font]
Could you please show any example ?
Thanks and best,
Aries Wink
Today, 02:02 AM
At integrating an equivalent to tanh(x)' the result is not as expected. There is no problem with sinh and cosh.
[Image: 46923421524_872517f26b_o.png]
Observation, using an equivalent expression returns the same result.
[Image: 46923421474_c4177df590_o.png]
Viga C | TD | FB
