New entry mode: python syntax
04-04-2019, 08:02 PM
Generally, every 6 months there is a new version of the HP-prime firmware, although it should be more frequent.
A very important feature to adhere to in the next firmware is a new entry mode: python syntax, which is only supported from a program code
LO SUFICIENTEMENTE BUENO ES ENEMIGO DE LA EXCELENCIA.
04-04-2019, 10:22 PM
RE: New entry mode: python syntax
(04-04-2019 08:02 PM)compsystems Wrote:  Generally, every 6 months there is a new version of the HP-prime firmware, although it should be more frequent.
Are you saying there will be a Python entry mode or that there should be?
Tom L
French phrases you rarely hear: "trop de beurre" (too much butter)
