HP-85B
02-18-2019, 11:53 PM
HP-85B
which command use to know which address (example :700) the floppy drive that is plugged into my hp-85b?
Systems Analyst
My passions (Facebook)
48G+/58C/85B/PC1500A
TH-78A/Samsung A51
Focal & All Basic´s
02-19-2019, 12:40 AM
RE: HP-85B
(02-18-2019 11:53 PM)hp41cx Wrote:  which command use to know which address (example :700) the floppy drive that is plugged into my hp-85b?
The address is specified by jumper switches on the drive itself, not by the CPU / OS. Typically there is a dip-switch panel on the rear of the drive, however exact details vary my drive model. What kind of drive is it?
02-19-2019, 12:54 AM
RE: HP-85B
I remember I had a command that showed the address of the drive drive unlike MSI ": D700: '" it was used print command [end line] showed in the video :D700
Systems Analyst
TH-78A/Samsung A51
Focal & All Basic´s
02-19-2019, 01:16 AM
RE: HP-85B
(02-19-2019 12:54 AM)hp41cx Wrote:  I remember I had a command that showed the address of the drive drive unlike MSI ": D700: '" it was used print command [end line] showed in the video :D700
The command MSI ':DXXX' sets which drive is the current default drive (i.e. which drive is used be default if you use commands like CAT without specifying a drive). The command 'MSI' is short for 'Mass Storage Is', and was not built-in, but added via system extensions like the one from Everett Kaser.
02-19-2019, 09:10 AM
RE: HP-85B
Maybe are you thinking to the MSUS$ function. It is in the Electronic Disc ROM, so built-in the HP85B.
J-F
02-19-2019, 09:54 AM
RE: HP-85B
85 x thanks J-F :-)
Systems Analyst
TH-78A/Samsung A51
Focal & All Basic´s
02-19-2019, 03:01 PM
RE: HP-85B
Yes, thanks very much JF, I didn't know this command. No doubt it's in the manual, one of too many I haven't had time to read...
