HP-71B LCD Problem! How Common?
02-16-2019, 11:34 PM
I received an HP-71B claulctor from TAS. The machine is in very good phsyical shape. You can say it was not used much. Hoever, when I typed a series of 8s across the LCD, the LCD displaye dthem correctly for less than a second and then displays bar-like charcaters in the middle of the LCD.
How common is this? Have you seen such a problem. I sure have not!
I appreciate feeback!
Namir
02-17-2019, 12:11 AM
RE: HP-71B LCD Problem! How Common?
Hi Namir,
I have a 71B that occasionally will have similar LCD issues, wherein the bottom few rows of dots turn-off along the full width of the display. Pressing down on the bezel below the LCD will usually restore the full LCD; thereafter, it may not occur for months or it might the next day.
Obviously some kind of semi-loose connection, it does not seem to be affected by bumping or positioning the machine oddly, or other handling effects. I can only guess, but I suspect environmental effects (temperature, humidity, ??) may explain the intermittent behavior.
Give it try and report results.
02-17-2019, 01:46 AM
(02-17-2019 12:11 AM)rprosperi Wrote:  Hi Namir,
I first discovered the ssue after inserting an HP-IL module and executing the VER$ command. The output was long enough to cover most of the LCD. Itshowed that the middle characters turning into intermittent vertical bars. I tried another HP-IL module and got the same thing! Then I typed 8s (with no HP-IL module plugged in) and saw the same issue. In between I took a battery out and put it back in. Same problem.
The atual seller is working through a clearance vendor on eBay. That vendor wrote me and said that after I informed him about the LCD problem, he tested two more new HP-71B units he had AND FOUND THAT THEY HAD TEH SAME LCD PROBLEM!!! He claims that this is a common "bug" based on what he found on the Internet!!!!!!!!!!!!!! Not sure I am buying it!
I find that hard to believe UNLESS THEY ALL CAME FROM A BAD BATCH WERE THE UNITS SAT UNUSED AND THEREFORE LOOK LIKE NEW. That is why I am asking for others if they have seen the same problem.
Namir
02-17-2019, 02:00 AM
(02-17-2019 01:46 AM)Namir Wrote:  The atual seller is working through a clearance vendor on eBay. That vendor wrote me and said that after I informed him about the LCD problem, he tested two more new HP-71B units he had AND FOUND THAT THEY HAD TEH SAME LCD PROBLEM!!! He claims that this is a common "bug" based on what he found on the Internet!!!!!!!!!!!!!! Not sure I am buying it!
I call BS. It is extremely unlikely that multiple units have the same unheard-of before now problem; it's not even likely the vendor bothered to test the units, he's just coming up with an excuse to not swap you a good unit for the bad one you have. Ask the vendor to send you links where he "found" this information; when he can't, I'd demand a swap for another unit, which I suspect will miraculously self-heal on its way to you.
02-17-2019, 02:51 AM
I am asking the vendor for a full refund.
Namir
02-17-2019, 02:58 AM (This post was last modified: 02-17-2019 08:29 AM by Raymond Del Tondo.)
It *may* get a problem to all 71B units which have the same type of interconnection between the LCD and the pcb, namely the bacon strips. These tend to dry out over the decades, and shrink in consequence, leading to contact losses. It's the same as with the bacon strips on some HP-41 units, in the Voyagers, and in the Pioneers. The gold ring zebra strips are way better in that respect.
And here we come to the next problematic interconnection part of the HP-71B: The zebra strip between the upper and lower half of the case. Although they usually work fine, I have seen some which don't work reliably, leading to strange patterns on the LCD, in the best case. In worse cases, the unit simply won't work.
If more than one of those NOS 71B units has the same problem, then it simply happened as stated above.
Although many of the different HP calcs are over-engineered in various respects, they all have weak points, in this case the cheap bacon strip connectors.
EDIT: The Pioneers don't use a bacon strip for interconnection between the main pcb and the keyboard. The Pioneers use a foam pad (w/o electrical lines) which presses a foil pcb to another pcb. The effect is the same: A shrinking foam pad leads to loose contacts.
-- Ray
02-17-2019, 05:59 AM
(02-17-2019 02:58 AM)Raymond Del Tondo Wrote:
(02-17-2019 02:00 AM)rprosperi Wrote:  I call BS. It is extremely unlikely that multiple units have the same unheard-of before now problem; it's not even likely the vendor bothered to test the units, he's just coming up with an excuse to not swap you a good unit for the bad one you have. Ask the vendor to send you links where he "found" this information; when he can't, I'd demand a swap for another unit, which I suspect will miraculously self-heal on its way to you.
Raymond,
How many HP-71B have you encountered where part of the LCD characters appear as intermittent vertical bars?
Namir
02-17-2019, 08:24 AM
(02-17-2019 05:59 AM)Namir Wrote:  How many HP-71B have you encountered where part of the LCD characters appear as intermittent vertical bars?
Hi, there were three units of which I remember that effect. One of them could be repaired by replacing the interconnection between the upper and lower half with a suitable piece from another unit.
The percentage of units with that effect was small, given the many HP-71B units which went over my desk, but the general problem stays.
Interesting that in all cases it was one of the later units with changed interconnection
-- Ray
02-17-2019, 09:37 AM
Thanks for the information.
Namir
