INPUT & EVAL()
07-24-2018, 10:37 AM (This post was last modified: 07-24-2018 10:37 AM by Tyann.)
INPUT & EVAL()
Bonjour
j'ai fait quelques essais avec INPUT et EVAL() mais je n'obtiens que des messages
d'erreur.
Quelqu'un aurait-il fait des essais concluants ?
Hello
I did some tests with INPUT and EVAL() but I only get messages
error.
Has anyone done any conclusive tests?
Sorry for my english
07-24-2018, 10:56 AM
RE: INPUT & EVAL()
I have tried this:
EXPORT test()
  LOCAL d2ydx2, x, y, t;
  INPUT({ {x, [8], {35,60,0}},
          {y, [8], {35,60,1}},
          {t, [8], {35,60,2}} },
          "Parametric Equation 2nd Derivative",
          {"x = ", "y = ", "Parameter = "},
          {"Enter the x-function ", "Enter the y-function", "Enter the parameter variable"},
          {QUOTE(t^2-4),QUOTE(t^3-3*t),QUOTE(t)},
          {QUOTE(t^2-4),QUOTE(t^3-3*t),QUOTE(t)} );
  d2ydx2:=normal(diff((diff(y,t))/(diff(x,t)),t)/(diff(x,t))); //  Second derivative
  RETURN d2ydx2;
The default {reset,initial} parameters work, however, manually inputting new, (or changing existing) values, doesn't work. There are probably better ways to do this, but this is where I am at the moment...
-Dale-
07-24-2018, 04:24 PM
RE: INPUT & EVAL()
EXPORT INPEVAL
 LOCAL Vars={{'X',[0],{30,20,1}},
             {'Y',[0],{30,20,2}},
             {'Z',{10,20,30},{30,20,3}}};
 INPUT(EVAL(Vars));
 INPUT(EVAL(Vars({1,2})));
 INPUT(EVAL(Vars({2,3})));
 Vars(0):={'W',[0],{30,20,1}};
 INPUT(EVAL(Vars({2,4})));
 INPUT(EVAL(CONCAT({Vars(0)},Vars({2,3}))));
 LOCAL VHelp:={"▇▶Help for X◀▇",
               "▇▶Help for Y◀▇",
               "▇▶Help for Z◀▇"};
 LOCAL VSelect:={2,3};
 INPUT(EVAL(Vars(VSelect)),{},{},VHelp(VSelect));
Viga C | TD | FB
07-24-2018, 04:36 PM
RE: INPUT & EVAL()
DrD
Désolé j'ai été un peu laconique, message posté juste avant de partir au travail,
mais je voulais parler des nouvelles possibilités offertes par la mise à jour.
Sorry I was a bit laconic, message posted just before going to work,
but I wanted to talk about the new possibilities offered by the update.
Carlos295pz
Super, c'est exactement ce que j'essayais de faire, merci beaucoup.
Excellente cette nouvelle possibilité.
Great, that's exactly what I was trying to do, thank you very much.
Excellent this new possibility.
