Hp25c
06-20-2018, 09:02 PM
Hp25c
It lives! It’s working 100% ok.
Thanks to this thread below.
http://www.hpmuseum.org/cgi-sys/cgiwrap/...read=12608
It just needed a little aluminum foil wrapped around the terminal leads.
Im using a shapeways plastic power pack with a copper dual coiled spring
Question, is there a more permanent solution for the terminal leads?
The aluminum foil falls off when the pack is pulled out.
I can solder, but dont want to mess up the 25c terminal leads and do it incorrectly.
06-21-2018, 07:53 AM
RE: Hp25c
(06-20-2018 09:02 PM)dm123 Wrote:  Question, is there a more permanent solution for the terminal leads?
I think the ideal solution would be to insert new silver rivets in place of the corroded ones. Some time ago I bought a bag full on eBay but unfortunately they are metric size and a tiny bit too small to make good contact. So double check before ordering...
06-21-2018, 11:39 AM
RE: Hp25c
Big Grin
SCNR
Greetings,
    Massimo
