fixed. Problem with : operator
05-23-2018, 02:26 PM (This post was last modified: 07-20-2018 03:13 PM by compsystems.)
Hello, when writing an identifier that ends in two points, the emulator is blocked
a: [enter]
the error was detected when trying to assign to a:=1, after erasing "=1"
LO SUFICIENTEMENTE BUENO ES ENEMIGO DE LA EXCELENCIA.
05-23-2018, 02:33 PM
RE: BUG id:
Yes. My emulator after entering a: shut down completely. Physical one did reboot.
05-23-2018, 03:28 PM
RE: BUG id:
True, it happens in the CAS
Viga C | TD | FB
05-23-2018, 04:59 PM
RE: BUG id:
Seems to be fixed in my development version, I get a syntax error (this is probably a side-effect of early implementation of Python syntax compatibility). Fortunately, I don't believe many users will try to write an identifier with a : inside, : is not a valid char inside a variable name.
07-20-2018, 02:54 PM (This post was last modified: 07-20-2018 09:12 PM by compsystems.)
RE: BUG id:
Fixed =), thanks hp-prime team
"HP Prime Graphing Calculator
Software Version: 2.0.0.13865 (2018 07 06)
Hardware Version: Emu
CAS Version: 1.4.9 6x
