Most impressive/complex/amazing C-series program?
04-04-2018, 11:06 PM
What's the most impressive/complex/amazing/intricate/brilliant program for the 10C/11C/12C/15C/16C in your opinion and why?
04-04-2018, 11:16 PM
RE: Most impressive/complex/amazing C-series program?
(04-04-2018 11:06 PM)michaelzinn Wrote: What's the most impressive/complex/amazing/intricate/brilliant program for the 10C/11C/12C/15C/16C in your opinion and why? Fast and Accurate Trigonometric Functions on the HP-12C by Gerson Barbosa Other programs for the 11C and 15C do more, but for the limited resources in the 12C, this is an amazing program and accomplishment. If you think you know the 12C, spend time with this program and you will certainly learn more than you knew. --Bob Prosperi |
04-05-2018, 11:30 AM
It must be worth also mentioning Valentin Albillo's
HP-12C Tried & Tricky Trigonometrics (pdf) as mentioned in this thread. |
04-08-2018, 02:29 AM
(04-05-2018 05:17 PM)Mike (Stgt) Wrote: The most nugatory? What's an a.m. routine? I can see some tests in there, and a square root, but the concept's currently beyond me. (Post 198) Regards, BrickViking HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a) |
04-13-2018, 12:27 AM
Hi, brickviking: (04-08-2018 02:29 AM)brickviking Wrote: What's an a.m. routine? I can see some tests in there, and a square root, but the concept's currently beyond me. The code simply computes Pi using the formula: Pi = 2 * 2/sqrt(2) * 2/sqrt(2+sqrt(2)) * 2/sqrt(2+sqrt(2+sqrt(2))) * ... which converges to the 10-digit representation of Pi (3.141592654) using just 17 terms. The algorithm is very clearly seen in this HP-71B equivalent command-line version >FIX 9 @ F=0 @ P=2 @ FOR I=1 TO 17 @ F=SQR(2+F) @ P=2*P/F @ NEXT I @ P 3.141592654 If you want to see the convergence after each term, this simpler implementation I've independently concocted adds an intermediate stop (R/S) and removes the now unneeded test, decreasing the step count from 17 to 14: 01- 35 CLx 02- 36 ENTER 03- 2 2 *04- 34 X<>Y 05- 2 2 06- 40 + 07- 43 21 SQR 08- 10 / 09- 43 36 LSTx 10- 34 X<>Y 11- 2 2 12- 20 * 13- 31 R/S 14- 43,33 04 GTO 04 To run it in any HP-12C, set 9 decimals (f 9), go to the top of program memory (GTO 00), and use R/S to see the converging value after each new term, like this: f 9 GTO 00 R/S -> 2.828427126 R/S -> 3.061467460 R/S -> 3.121445154 R/S -> 3.136548492 R/S -> 3.140331160 --- R/S -> 3.141592648 R/S -> 3.141592652 R/S -> 3.141592654 After pressing R/S sixteen times the value has converged and there's no need to go on, any subsequent R/S would produce the same value (3.141592654) again. Note: the original code in the Code panel has one typo. Step 14 appears like this: 14-43,33 00 RTN but though the keycode is correct, it should read GTO 00 instead of RTN, like this: 14-43,33 00 GTO 00 because that's what the keycode indicates and there's no RTN instruction in the HP-12C's instruction set as there's no subroutine (GSB) capability either. Regards. V. Find All My HP-related Materials here: Valentin Albillo's HP Collection |
04-13-2018, 02:32 PM
(This post was last modified: 04-13-2018 02:35 PM by Gerson W. Barbosa.)
(04-13-2018 12:27 AM)Valentin Albillo Wrote: On the HP-41C: 01 LBL "V" 02 2 03 STO Y 04 LBL 00 05 SQRT 06 ST/ Y 07 2 08 ST* Z 09 + 10 VIEW Y 11 STOP 12 GTO 00 13 END Same usage (FIX 9, XEQ ALPHA V ALPHA, R/S, R/S...) and same results. Based on a 12-step program for the HP-12C by Katie Wassermann. Gerson. |
04-14-2018, 01:13 AM
(04-13-2018 10:47 PM)Mike (Stgt) Wrote: Hit 16 times R/S?? No - please - no. A counter proposal (print from Emu42 on HP82240B Printer Simulator): As you please: 00 { 30-Byte Prgm } 01▸LBL "V" 02 2 03 STO ST Y 04▸LBL 00 05 SQRT 06 STO÷ ST Y 07 2 08 STO× ST Z 09 X≤Y? 10 RTN 11 + 12 X<>Y 13 XEQ "FWIW" 14 X<>Y 15 GTO 00 16 .END. 2.8284271247461900976033 77448419396 ᴇ0 3.0614674589207181738276 7987224319 ᴇ0 3.1214451522580522855725 57895632356 ᴇ0 3.1365484905459392638142 58044436538 ᴇ0 3.1403311569547529123171 1852433169 ᴇ0 3.1412772509327728680620 19770788214 ᴇ0 3.1415138011443010763285 15059456822 ᴇ0 3.1415729403670913841358 00110270762 ᴇ0 3.1415877252771597006288 54262701918 ᴇ0 3.1415914215111999739979 71763740834 ᴇ0 3.1415923455701177423403 7599415737 ᴇ0 3.1415925765848726656816 06092237874 ᴇ0 3.1415926343385629890954 7826362779 ᴇ0 3.1415926487769856694851 07969277176 ᴇ0 3.1415926523865913458035 25521057964 ᴇ0 3.1415926532889927652719 4304217374 ᴇ0 3.1415926535145931201633 4824328108 ᴇ0 3.1415926535709932088877 18344859772 ᴇ0 3.1415926535850932310689 05795335812 ᴇ0 3.1415926535886182366142 08590772408 ᴇ0 3.1415926535894994880005 34660432656 ᴇ0 3.1415926535897198008471 16201022788 ᴇ0 3.1415926535897748790587 61587618764 ᴇ0 3.1415926535897886486116 72934358286 ᴇ0 3.1415926535897920909999 00771048824 ᴇ0 3.1415926535897929515969 57730221812 ᴇ0 3.1415926535897931667462 21970015082 ᴇ0 3.1415926535897932205335 380299634 ᴇ0 3.1415926535897932339803 6704495048 ᴇ0 3.1415926535897932373420 7429869725 ᴇ0 3.1415926535897932381825 01112133942 ᴇ0 3.1415926535897932383926 07815493116 ᴇ0 3.1415926535897932384451 3449133291 ᴇ0 3.1415926535897932384582 66160292858 ᴇ0 3.1415926535897932384615 49077532844 ᴇ0 3.1415926535897932384623 69806842842 ᴇ0 3.1415926535897932384625 74989170342 ᴇ0 3.1415926535897932384626 26284752218 ᴇ0 3.1415926535897932384626 39108647686 ᴇ0 3.1415926535897932384626 42314621554 ᴇ0 3.1415926535897932384626 43116115022 ᴇ0 3.1415926535897932384626 43316488388 ᴇ0 3.1415926535897932384626 4336658173 ᴇ0 3.1415926535897932384626 43379105066 ᴇ0 3.1415926535897932384626 433822359 ᴇ0 3.1415926535897932384626 43383018608 ᴇ0 3.1415926535897932384626 43383214286 ᴇ0 3.1415926535897932384626 43383263206 ᴇ0 3.1415926535897932384626 43383275436 ᴇ0 3.1415926535897932384626 43383278494 ᴇ0 3.1415926535897932384626 43383279258 ᴇ0 3.1415926535897932384626 4338327945 ᴇ0 3.1415926535897932384626 43383279498 ᴇ0 3.1415926535897932384626 4338327951 ᴇ0 3.1415926535897932384626 43383279514 ᴇ0 3.1415926535897932384626 43383279516 ᴇ0 Perhaps it is possible to do it without the external program FWIW (SHOW is not programmable). Gerson. P.S.: Here is a link to Katie Wasserman's original HP-12C program: http://www.hpmuseum.org/cgi-sys/cgiwrap/...118#101119 |
04-14-2018, 03:40 AM
(This post was last modified: 04-14-2018 03:57 AM by Gamo.)
To me the most impressive program is finding the root of unlimited polynomial equation that used the NPV IRR build-in functions in HP-12C was program by Valentin This is very amazing that it make 12C very powerful.
SOLVE for HP-12C is a nice one to have too. The Newton's Method program for 12C Gamo |
04-14-2018, 09:29 AM
(04-14-2018 05:31 AM)Mike (Stgt) Wrote:(04-14-2018 01:13 AM)Gerson W. Barbosa Wrote: 00 { 30-Byte Prgm } Yes, that’s for Free42 only. VIEW Y on Free42 would exhibit only the first 12 significant digits. The FWIW program is mentioned in this thread, but it’s not available in the Free42 website anymore. Gerson. |
04-14-2018, 10:14 AM
(04-14-2018 09:29 AM)Gerson W. Barbosa Wrote: Yes, that’s for Free42 only. VIEW Y on Free42 would exhibit only the first 12 significant digits. The FWIW program is mentioned in this thread, but it’s not available in the Free42 website anymore. Hmm. Yes, I removed that program after I implemented full-precision Copy and SHOW, figuring those changes made it redundant. I didn't think about printing full precision, though. Gerson, if you could send me your copy, I'll put it back. |
04-14-2018, 11:23 AM
(This post was last modified: 04-14-2018 11:24 AM by Gerson W. Barbosa.)
(04-14-2018 10:14 AM)Thomas Okken Wrote:(04-14-2018 09:29 AM)Gerson W. Barbosa Wrote: Yes, that’s for Free42 only. VIEW Y on Free42 would exhibit only the first 12 significant digits. The FWIW program is mentioned in this thread, but it’s not available in the Free42 website anymore. Here it is: 00 { 404-Byte Prgm } 01▸LBL "FWIW" 02 GTO 01 03▸LBL 00 04 "↓ bin≤16 dec≤34" 05 34 06 "↓ grouping size" 07 34 08 "↓ 1=SCI 3=ENG" 09 3 10 RTN 11▸LBL 01 12 REAL? 13 GTO 02 14 GTO 10 15▸LBL 02 16 X=0? 17 GTO 10 18 X<>Y 19 STO ".Y." 20 R↓ 21 STO ".X." 22 R↓ 23 STO ".Z." 24 R↓ 25 STO ".T." 26 LASTX 27 STO ".L." 28 R↑ 29 XEQ 00 30 STO ".M." 31 R↓ 32 STO ".G." 33 R↓ 34 1 35 - 36 STO ".J." 37 CLA 38 R↓ 39 SIGN 40 LASTX 41 ABS 42 ENTER 43 LOG 44 ENTER 45 X≥0? 46 GTO 03 47 FP 48 X=0? 49 GTO 03 50 R↓ 51 IP 52 1 53 - 54 ENTER 55▸LBL 03 56 R↓ 57 IP 58 STO ".E." 59 RCL ".M." 60 MOD 61 STO- ".E." 62 STO- ".J." 63 R↓ 64 RCL ".E." 65 10↑X 66 X=0? 67 GTO 08 68 ÷ 69 × 70 AIP 71 FS? 28 72 ├"." 73 FC? 28 74 ├"," 75 LASTX 76 FP 77 RCL ".G." 78 X<>Y 79▸LBL 04 80 10 81 × 82 AIP 83 FP 84 DSE ".J." 85 X=0? 86 GTO 06 87 DSE ST Y 88 GTO 04 89 ALENG 90 22 91 X≤Y? 92 GTO 05 93 X<>Y 94 RCL+ ".G." 95 X<Y? 96 GTO 05 97 R↓ 98 LASTX 99 RCL+ ".J." 100 X≥Y? 101 ├"[LF]" 102▸LBL 05 103 ├" " 104 RCL ".G." 105 R↑ 106 GTO 04 107▸LBL 06 108 ALENG 109 22 110 X≤Y? 111 GTO 07 112 10 113 POSA 114 X<0? 115 ├"[LF]" 116▸LBL 07 117 ├" ᴇ" 118 RCL ".E." 119 AIP 120 GTO 09 121▸LBL 08 122 "Went out of" 123 ├" range! :(" 124▸LBL 09 125 AVIEW 126 CLA 127 RCL ".L." 128 STO ST L 129 RCL ".T." 130 RCL ".Z." 131 RCL ".Y." 132 RCL ".X." 133 CLV ".M." 134 CLV ".G." 135 CLV ".J." 136 CLV ".E." 137 CLV ".L." 138 CLV ".T." 139 CLV ".Z." 140 CLV ".Y." 141 CLV ".X." 142▸LBL 10 143 END |
04-14-2018, 01:14 PM
Thanks! I put it back and also updated the annotated listing.
04-14-2018, 03:09 PM
(This post was last modified: 04-14-2018 03:09 PM by Gerson W. Barbosa.)
(04-13-2018 12:27 AM)Valentin Albillo Wrote: \(\pi\) and \(\sqrt{2}\) have always been close friends, it appears :-) \(\frac{\rm{\pi}+{\rm{\pi}}^{2}+{\rm{\pi}}^{3}+{\rm{\pi}}^{4}-{\left({2}^{6}+{2}^{7}\right)}^{-1}}{\sqrt{2}}=100.0000001402465\) The near-integer result above might be just a coincidence, though. Gerson. |
04-15-2018, 12:31 AM
(04-14-2018 03:09 PM)Gerson W. Barbosa Wrote:(04-13-2018 12:27 AM)Valentin Albillo Wrote: Dude, you must be exceedingly bored.... LOL. Though I must admit that is a very suspicious looking number.... and most often, these are not coincidences, though looking again at the equation.... nah, you were just bored. --Bob Prosperi |
04-15-2018, 01:37 AM
(04-15-2018 12:31 AM)rprosperi Wrote: Dude, you must be exceedingly bored.... LOL. You couldn’t be more right :-) Fill the stack with pi, then repeat * + three times. It shouldn’t be difficult to recognize the first five significant digits. Divide by the square root of 2. Then press the square root key. That’s our 10. pi 34 y^x pi EEX 12 * 3 / - EEX 16 / —> 7.9999999953 Ten more of these and we can make one of those nerd clocks. An original one. Perhaps next time I get bored :-) |
04-15-2018, 09:51 AM
(This post was last modified: 04-16-2018 03:41 PM by EdS2.)
(04-14-2018 03:09 PM)Gerson W. Barbosa Wrote: \(\frac{\rm{\pi}+{\rm{\pi}}^{2}+{\rm{\pi}}^{3}+{\rm{\pi}}^{4}-{\left({2}^{6}+{2}^{7}\right)}^{-1}}{\sqrt{2}}=100.0000001402465\)Remarkable. Wolfram Alpha offers 45/2 - 53/(4 π) - 18/sqrt(π) + (23 sqrt(π))/4 + 26 π≈100.000000140246501794 which is, I guess, the same number. [Edit: no, it's different] |
04-15-2018, 11:23 AM
(04-15-2018 12:31 AM)rprosperi Wrote: Dude, you must be exceedingly bored.... LOL.Using your post as input. I always think that bored people are boring as well. Instead I am amazed by the way Gerson, Valentin and others have a question or a path to find some formulas. Like "ok, today I'll try to get the best approximation of 100 using combination of PI and square root, then refining with other numbers". What I appreciate in this case is the quest itself. Is that they have a quest to accomplish (that is pretty fancy when solved). Too many times I see people saying "I do not know what to do". Wikis are great, Contribute :) |
04-15-2018, 10:10 PM
(04-15-2018 01:37 AM)Gerson W. Barbosa Wrote: You couldn’t be more right :-) This kind of mental/mathematical wandering has always made me wonder how much more interesting this kind of meandering would be with an infinite precision calculator. You could immediately tell if indeed you found some kind of sequence of consequence if it produced, e.g. 100 or 8 exactly for the types of problems listed above, or if they're just numbers that coincidentally look close to those numbers. But of course, with an infinite precision calculator, you could simply press the "PI" button, then sit back, smile and relax, having very quickly accomplished an amazing feat indeed. ![]() --Bob Prosperi |
04-15-2018, 11:58 PM
Curious. On my Mac using "bc".
04-17-2018, 01:32 AM
Hi, EdS2: (04-15-2018 09:51 AM)EdS2 Wrote:(04-14-2018 03:09 PM)Gerson W. Barbosa Wrote: \(\frac{\rm{\pi}+{\rm{\pi}}^{2}+{\rm{\pi}}^{3}+{\rm{\pi}}^{4}-{\left({2}^{6}+{2}^{7}\right)}^{-1}}{\sqrt{2}}=100.0000001402465\)Remarkable. Wolfram Alpha offers Indeed they're different: (\(\pi+\pi^2+\pi^3+\pi^4-(2^6+2^7)^{-1})/\sqrt{2}\) = 100.000000140246548564343[...] 45/2-53/(4\(\pi\))-18/\(\sqrt{\pi}\)+23\(\sqrt{\pi}\)/4+26\(\pi\) = 100.000000140246501794052[...] Wolfram Alpha's attempt is very poor as it uses far too many digits (13, plus 4 instances of \(\pi\)) and operations (again, 13) to get a mere 9 digits, "100.000000". V. . Find All My HP-related Materials here: Valentin Albillo's HP Collection |
