(25) 55 Applications Programs for Teenix MultiCalculator Emulator and Hardware
01-28-2018, 10:09 PM
(This post was last modified: 02-04-2018 09:40 PM by mfleming.)
This is a collection of the 55 programs in the HP-25 Applications Programs manual, suitable for loading into the Teenix MultiCalculator emulator, hardware calculator, or the Classic upgrade board.
In the attached ZIP file you'll find all 55 programs organized into two library directories for easy import into a hardware calculator memory block of 32 program locations. There are also two Excel files and their PDF output, one in US Letter format and the other in A4 format. These sheets identify which file has which program, and where each program is loaded into a block and memory location. The sheets are also useful in keeping track of other programs you have loaded into your hardware calculator. See the attached PDF file for details. Each program was entered and tested in the emulator. They have also been loaded into a Harald & Tony Classic upgrade board and spot checked. I do not have the equipment to test the A4 format sheet and PDF for proper printing. Enjoy! ~Mark 3-February-2018. I've updated the attached ZIP file to include the listings for each of the individual programs. The Teenix emulator has a program editor that allows you to edit a program in memory as text, and to save that program as a text file. Comments can be added to the file following two slash characters, i.e. '// comment' The listings help identify each program by placing the program title as an opening comment. They also served to validate correct entry of each program from the HP manual. Remember kids, "In a democracy, you get the government you deserve." |
01-28-2018, 10:49 PM
RE: (25) 55 Applications Programs for Teenix MultiCalculator Emulator and Hardware
(01-28-2018 10:09 PM)mfleming Wrote: This is a collection of the 55 programs in the HP-25 Applications Programs manual, suitable for loading into the Teenix MultiCalculator emulator, hardware calculator, or the Classic upgrade board. Hi Mark, Awesome and a lot of work no doubt. Can I post them on the teenix site? cheers Tony |
01-28-2018, 11:25 PM
Thanks for those Mark!
01-28-2018, 11:39 PM
(01-28-2018 10:49 PM)teenix Wrote: Hi Mark, Absolutely! Remember kids, "In a democracy, you get the government you deserve." |
02-04-2018, 01:10 AM
I've updated the ZIP file in the original post to include the listings for each individual program. The Teenix emulator has a program editor that you can use to edit a program and to save that program as a text file. Comments can be added to the file following two slash characters, i.e. '// comment'
The listings help identify each program by placing the program title as an opening comment. They also served as a check on correct entry of each program from the HP manual. ~Mark Remember kids, "In a democracy, you get the government you deserve." |
02-04-2018, 03:31 AM
If anyone can, please consider adding these programs to the library.
https://www.dropbox.com/s/tsazrvab1jykyr...s.pdf?dl=0 They come from the HP 25 Library put together by James Davidson in the PPC Journal. All of these are fabulous works of art. |
07-16-2022, 04:36 PM
The chapter Emulator Card File Format in the Notes on HP’s Classic Calculators allowed me to decode the *.pgf files and translate them into a format that can be used in this HP-25C emulator.
Enjoy and have fun. Example Programs/Library1/HP25-AP06.25: Code: 01: 23 01 : STO 1 Contents hp-25-applications-programs.zip (Size: 24.35 KB / Downloads: 10) Code: Archive: hp-25-applications-programs.zip hp-25-ppc.zip (Size: 28.51 KB / Downloads: 9) Code: Archive: hp-25-ppc.zip References |
