HP 50g: Neighbour Function (Dedekind Cut) Programme Challenge
09-27-2017, 07:33 AM
In this thread
http://www.hpmuseum.org/forum/thread-9156.html
Joe Horn reminds us of the NEIGHBOR function for the HP 71-B.
I have a 270.5 Byte programme which for real input returns both the upper & lower neighbours of input on the 50g.
Can anyone produce a shorter programme?
09-27-2017, 07:39 AM (This post was last modified: 09-27-2017 07:40 AM by Joe Horn.)
RE: HP 50g: Neighbour Function (Dedekind Cut) Programme Challenge
I'd LOVE to see your program. For years I've been living with this atrocity called NABR. It adds X ULPS onto Y. Example: 5 ENTER 2 NABR --> 5.00000000002
<< SWAP DUP XPON SWAP MANT .00000000001 4. ROLL * + SWAP ALOG * >>
Fails when Y=0, and gets the wrong answer for 1 ENTER -1 NABR.
<0|ɸ|0>
-Joe-
09-27-2017, 07:49 AM (This post was last modified: 09-27-2017 07:51 AM by Gerald H.)
(09-27-2017 07:39 AM)Joe Horn Wrote:  I'd LOVE to see your program. For years I've been living with this atrocity called NABR. It adds X ULPS onto Y. Example: 5 ENTER 2 NABR --> 5.00000000002
Doesn't work.
Edit: Does work.
09-27-2017, 07:50 AM
Sorry, works.
09-27-2017, 07:52 AM
Very nice, could be the basis of an answer to my post.
09-27-2017, 08:06 AM
(09-27-2017 07:52 AM)Gerald H Wrote:  Very nice, could be the basis of an answer to my post.
After struggling with this, I gave up on it years ago. Please share your program. I'd love to see how you did it! Or is this a kind of mini-challenge? If so, I can't wait to see what folks here come up with!
<0|ɸ|0>
-Joe-
09-27-2017, 09:12 AM
Yes, I would very much appreciate contributions in the way of programmes or algorithms.
Your programme fails for input
-5
3
& will have to grow to accommodate negative reals.
I will certainly timely publish my programme but do not expect it to be the shortest.
09-27-2017, 10:43 AM (This post was last modified: 09-27-2017 11:25 AM by Werner.)
I created this when Joe first mentioned the NEIGHBOR function.
It returns the next number larger than x=s*m*10^n
Basically, if x=0, return 1e-499
elsif s*m=-1, return (s.m + 1e-12)*10^n
else return (s.m + 1e-11)*10^n
  IF DUP
  THEN DUP XPON ALOG
  ELSE 1E-488 END
  SWAP OVER /     @ 10^n s*m
  DUP -1 \=/ 6 - 6 - ALOG + *
If I call this program NXT, then NEIGHBOR as defined in the 71 would be
\<< IF OVER < THEN +/- NXT +/- ELSE NXT END \>>
Cheers, Werner
09-27-2017, 11:22 AM (This post was last modified: 09-27-2017 11:23 AM by pier4r.)
Nice input Gerald and Joe!
I have a question though. From the other thread
Quote:NEIGHBOR(X,Y) [nearest machine-representable number to X in the direction of Y]
Wouldn't be Y representable by the system already? My doubt lies on the point that that the value given to the function is already a valid value for the system, so there is nothing to search.
Would be different with a string in input rather than a number.
09-27-2017, 11:51 AM
(09-27-2017 11:22 AM)pier4r Wrote:  I have a question though. From the other thread
Sorry, but I don't understand your question. The only thing that Y does is tell NEIGHBOR which direction to go. If Y>X, then NEIGHBOR(X,Y) returns the very next number GREATER than X which the HP-71 is capable of representing, and if Y<X then it returns the very next number LESS than X. The phrase "machine-representable number" means "limited to a 12-digit mantissa". The function has nothing to do with strings.
Examples:
NEIGHBOR(6,9) --> 6.00000000001 (the nearest machine-representable number above 6)
NEIGHBOR(6,2) --> 5.99999999999 (the nearest machine-representable number below 6)
<0|ɸ|0>
-Joe-
09-27-2017, 11:53 AM (This post was last modified: 09-28-2017 05:36 AM by Gerald H.)
Bravo Werner! I consider your contribution a complete solution & don't expect a shorter version (although "6 - 6 -" is ornate), would however be very pleased to see a more concise programme.
To keep my word & amuse Joe here's my version:
Edit: Corrected my programme to give correct result for zero. I have learned much from this thread, eg that .000000000001 is not the nearest representable number to zero.
I doubt that, given Werner's programme, anyone will now try this programme but the wrong result irritated me.
  CK1&Dispatch
  # FF
    Z1_
    FPTR2 ^RADDext
    DUP
    Z2_
    FPTR2 ^RSUBext
  BINT1
    DUP%0=
    casedrop
      %MINREAL
      DUP
      %CHS
    DUP
    %SGN
    SWAP
      %ABS
      DUP
      DO>STR
      DUP
      "E"
      BINT1
      POSCHR
      DUPUNROT
      2DUP
      LAST$
      3UNROLL
      1_#1-SUB$
      DUPLEN$
        #1=case
          ".00000000001"
          SWAP&$
          DOSTR>
          SWAPDROP
        ROTDUP
        BINT14
        ITE
          BINT14
          SWAP#-
          ZERO_DO
          CHR_0
          >T$
          LOOP
        DROP
        CHR_6
        >T$
        SWAP&$
        DOSTR>
      DUPDUP
      4ROLL
      DUP
      %MANTISSA
      %1
      case
        2%>%%
        DUP
        %%10
        SWAP
        SWAP
      %2
    ROT
    %0>
    ?SEMI
    %CHS
    SWAP
    %CHS
Which does have the advantage of giving no wrong answers, ie for input
9.99999999999E499
1
Joe's returns
9.99999999999E499
& for
9.99999999999E499
9.99999999999E499
Werner's returns
9.99999999999E499
while for
9.99999999999E499
my programme errors.
I can't believe the 50G doesn't have this function.
I'm confident it is present internally somewhere.
Pauli
09-27-2017, 12:24 PM
Joe: what does NEIGHBOR return if X=Y?
Gerald:
(09-27-2017 11:53 AM)Gerald H Wrote:  for
9.99999999999E499
9.99999999999E499
Werner's returns
9.99999999999E499
No, it errors out, as (for now) it considers it has to go up to the next number.
I guess your overflow flag is cleared, then it returns 9.99999999999e499
I'd say when X=Y the number should be returned unchanged, so:
  IF DUP2 SAME THEN DROP
  ELSE
    IF OVER < THEN NEG NXT NEG ELSE NXT END
  END
09-27-2017, 01:01 PM
(09-27-2017 12:24 PM)Werner Wrote:  Joe: what does NEIGHBOR return if X=Y?
Some interesting inputs & outputs on HP-71:
NEIGHBOR(7,7) --> 7
NEIGHBOR(0,0) --> 0
NEIGHBOR(0,7) --> 0.00000000001E-499 = MINREAL (non-normalized)
NEIGHBOR(1,0) --> 0.999999999999 (twelve 9's, not just eleven like my buggy program above)
<0|ɸ|0>
-Joe-
09-27-2017, 01:04 PM
Thanks, Joe
My program above returns correct results for all of these. The 1e-499 is normalized, though ;-)
Werner
09-27-2017, 01:40 PM (This post was last modified: 09-27-2017 01:41 PM by pier4r.)
(09-27-2017 11:51 AM)Joe Horn Wrote:  Sorry, but I don't understand your question. The only thing that Y does is tell NEIGHBOR which direction to go. If Y>X, then NEIGHBOR(X,Y) returns the very next number GREATER than X which the HP-71 is capable of representing, and if Y<X then it returns the very next number LESS than X. The phrase "machine-representable number" means "limited to a 12-digit mantissa". The function has nothing to do with strings.
Examples:
Ah, ok, then I misunderstood. I thought the right function was like 'Y' is not representable by the system, can you give the closer number to Y, starting from X, that can represent Y?
09-27-2017, 03:12 PM (This post was last modified: 09-27-2017 03:13 PM by David Hayden.)
Slow and simple, but it works. This just keeps adding or subtracting 10^n for successively larger values of n until X+10^n changes.
@ NEIGHBOR
@ Given X & Y (X on lvl2, Y on lvl1), find the next
@ number to X in the direction of Y that the calc can
@ represent.  If X=Y then return X
OVER - SIGN  @ X (-1,0,1)
1E-499 *
IF DUP THEN  @ Special case for X==Y
    WHILE DUP2 + PICK3 ==
    REPEAT
       10. *
    END
END
09-27-2017, 03:39 PM
Well done, David.
Gives wrong answer for input
1.E-499
6
returns
2.E-499
should be
1.00000000001E-499
09-28-2017, 10:15 AM
Many thanks for the contributions, I'm very pleased with the resulting programmes.
Please see
http://www.hpmuseum.org/forum/thread-9180.html
which will assist students greatly (I hope).
