Programming Exercise (HP-15C, 15C LE - and others)
03-29-2014, 08:51 PM
Post: #61
RE: Programming Exercise (HP-15C, 15C LE - and others)
(03-29-2014 08:07 PM)Tugdual Wrote:  Hmmm kinda depend on the version you have now Smile
Could it be from 2013-08? IIRC it was the first official release. Though I only seldom read Prime-related threads I realized that there was a recent bugfix-release. But I don't know whether the emulator was updated as well.
It wasn't possible to copy the release-information as text. Thus I didn't include it in my previous post. And right now I don't have access to the emulator anymore.
But don't worry: the question is barely worth the effort.
Kind regards
03-29-2014, 09:19 PM
Post: #62
Kind regards
In order to update (or check version) you may simply start the connection Kit and then in the help menu there is an option to check the latest version.
03-30-2014, 12:07 AM
Post: #63
(03-28-2014 03:18 AM)bkn42 Wrote:  I implemented the two term version of this on my "HP55".
Here is the code (sorry its not in location/keycode form but you get the idea):
  STO 0
  0
  STO 1
08:  X<>Y
  ENTER
  ENTER
  1/x
  STO + 1
  2
  STO - 0
  RCL 0
  0
  X<=Y 0 8
  RCL 1
  GTO 0 0
R0 holds the current iteration and R1 is the series sum.
For N=100, it took about 82sec to finish. Based on this it would take about 2.25hours for N=10000.
The following is a direct conversion of the HP-15C program to calculate pi in the beginning of this thread, so it's rather long: 49 steps, all the programming memory space of the HP-55!
01 ENTER
02 STO
03 0
04 STO
05 +
06 0
07 4
08 STO
09 1
10 *
11 1/x
12 +
13 1/x
14 STO
15 2
16 CLx
17 ENTER
18 ENTER
19 Rv
20 Rv
21 1
22 STO
23 -
24 0
25 Rv
26 RCL
27 1
28 CHS
29 STO
30 1
31 RCL
32 0
33 /
34 +
35 1
36 STO
37 -
38 0
39 Rv
40 RCL
41 0
42 2
43 f
44 x<=y 19
45 Rv
46 Rv
47 RCL
48 2
49 +
66 R/S --> 3.141592654 (2 m 37 s)
03-30-2014, 12:51 AM
Post: #64
(03-30-2014 12:07 AM)Gerson W. Barbosa Wrote:  66 R/S --> 3.141592654 (2 m 37 s)
I took your program and put it on the HP-67. Same result in 1 m 16 s. The other HP-55 program when run on the hp-67 had run a little less than twice as fast, while this ran a little more than twice as fast. With the exception of the label for the goto, the programs are identical.
I assume that the difference is that this program is longer and the penalty for the non-merged instructions is making the difference.
03-30-2014, 01:38 AM (This post was last modified: 03-30-2014 01:39 AM by Gerson W. Barbosa.)
Post: #65
I'd better have used another register for summing up the terms rather than the stack. This would save at least two steps inside the loop. No more than some ten second gain, I think (unless some optimization is tried - no idea about though). Even the prefix key takes up one step. This makes 49 steps almost nothing!
03-30-2014, 03:12 AM
Post: #66
My FPGA "HP-55" gets the same answer but in under 1/2 second in turbo mode. Smile
Brian
03-30-2014, 03:51 AM (This post was last modified: 03-30-2014 04:20 AM by Gerson W. Barbosa.)
Post: #67
Brian
Thank you for bringing the HP-55 (and your "HP-55") in here! Funny to see how calculators were like back then. In 1982 I had a TI-59 for a while ( no continuous memory, but it had magnetic card reader), then next year something much better: an HP-15C.
At first I thought you had converted the pi program to the "HP-55" like the previous one for the ln(2) series, judging by the picture in your detailed thread on the "HP-55", but then I realized it was the rational approximation 355/113. This one appears in the small HP-35 manual, BTW.
Gerson.
Updated to include hyperlink
03-31-2014, 04:18 AM
Post: #68
(03-30-2014 03:51 AM)Gerson W. Barbosa Wrote:  At first I thought you had converted the pi program to the "HP-55" like the previous one for the ln(2) series, judging by the picture in your detailed thread on the "HP-55", but then I realized it was the rational approximation 355/113. This one appears in the small HP-35 manual, BTW.
Its when I started my HP Calculator FPGA project, I first saw the 355/113 approximation for PI in the HP-35 manual. I used it as a first test of my FPGA design.
On a side note, since there is a lot of execution times being posted here, I tried turning up the internal clock rate of my "HP-55". I never designed it for speed just to be functionally equivalent to the classic HPs. However, I was able to get my current design to run at 84MHz (a 3x increase) -- this is not too bad for the FPGA I'm using. Anyway, all the execution times I posted are now one third of what I stated.
Brian
03-31-2014, 06:42 PM
Post: #69
I tried the "two-terms-at-a-time" method on my HP-32SII:
A01 LBL A
A02 0.00002
A03 +
A04 1
A05 -
A06 STO I
A07 0
L01 LBL L
L02 RCL I
L03 IP
L04 ENTER
L05 ENTER
L06 x
L07 +
L08 1/x
L09 +
L10 DSE I
L11 GTO L
L12 RTN
10000 XEQ A
Yields: 0.69309718306 in about 5min 15sec
Brian
03-31-2014, 07:22 PM
Post: #70
This might be a little faster:
L04 ENTER
L05 x^2
L06 +
03-31-2014, 07:49 PM
Post: #71
(03-31-2014 07:22 PM)Thomas Klemm Wrote:  This might be a little faster:
L04 ENTER
L05 x^2
L06 +
Yes, that is a little faster! Run time now is about: 4min 51secs
Brian
03-31-2014, 08:01 PM
Post: #72
L04 ENTER
L05 x^2
L06 +
And this is is a little shorter:
A01 LBL A
A02 0.00002
A03 +
A04 STO I
A05 0
L01 LBL L
L02 RCL I
L03 IP
L04 ENTER
L05 x^2
L06 -
L07 1/x
L08 -
L09 DSE I
L10 GTO L
L11 RTN
My HP-32SII is slower than Brian's: 5 m 29s here.
Cheers,
Gerson.
03-31-2014, 08:27 PM
Post: #73
A very unremarkable version for my Tandy PC-3 (AKA Sharp PC-1251), which uses BASIC:
10 "L":AREAD C
20 X=0
30 FOR I=C TO 1 STEP -1
40 X=X+(1/I)*((-1)^(I+1))
50 NEXT I
60 PRINT X
70 END
Switch to RUN mode, enter the number of iterations, and press DEF L to start. I get 100 loops in about 32 seconds, so 10000 would take around 54 minutes. Not an especially fast machine.
03-31-2014, 10:13 PM
Post: #74
I was impressed with the timings seen on the 42s and 34s using the "two terms at a time" approach. I didn't think a 50g would do as well, so I thought I'd give it a shot to see what might happen.
UserRPL version:
   TICKS
   0
   10000.
   1.
   FOR n
      n DUP 1. - * INV
   -2. STEP
   TICKS ROT - B\->R 8192. /
Final Value: 0.69309718306
Avg. of 5 runs: 42.745 seconds
I was curious as to how different a SysRPL version of this might be, so I tried the following. I've added comments to (hopefully) make it a bit easier to follow the logic.
SysRPL:
RPL
DEFINE   TotalLAMs         BINT3
DEFINE   RCL_StartTime     3GETLAM
DEFINE   STO_n             2PUTLAM
DEFINE   RCL_n             2GETLAM
DEFINE   STO_sum           1PUTLAM
DEFINE   RCL_sum           1GETLAM
   ( no args required )
   CK0NOLASTWD
   ( place local vars on stack )
   SysTime     ( StartTime )
   %% 10000    ( n )
   %%0         ( sum )
   ( bind local vars )
   NULLLAM TotalLAMs NDUPN DOBIND
   ( loop counter - do [n/2] times )
   RCL_n %%>% COERCE #2/
   ( main loop )
   #1+_ONE_DO (DO)
      ( determine current expression value )
      RCL_n DUP %%1 %%- %%* %%1/
      ( add value to running sum )
      RCL_sum %%+ STO_sum
      ( decrement n by 2 )
      RCL_n %%2 %%- STO_n
   LOOP
   ( convert extended real to user real )
   RCL_sum %%>%
   ( determine run time )
   SysTime RCL_StartTime bit- HXS>% % 8192 %/
   ( release local var bindings )
   ABND
Avg. of 5 runs: 20.318 seconds
Not surprisingly, the SysRPL version was noticeably faster. But still not as good as the 42s/34s versions.
Besides the speed difference, the SysRPL version also affords the opportunity to see the 15-digit result of the sum if you don't do the final conversion:
0.693097183059944 (it actually displays as "6.93097183059944E-1"). "Extended Reals" are of no use outside the context of a running SysRPL code object, but it's nice to see all the digits that were retained in the calculations.
04-01-2014, 02:57 AM
Post: #75
(03-31-2014 10:13 PM)DavidM Wrote:  I was impressed with the timings seen on the 42s and 34s using the "two terms at a time" approach. I didn't think a 50g would do as well, so I thought I'd give it a shot to see what might happen.
UserRPL version:
   TICKS
   0
   10000.
   1.
   FOR n
      n DUP 1. - * INV
   -2. STEP
SysRPL:
RPL
   CK0NOLASTWD
   %% 10000    ( n )
   %%0         ( sum )
   ( bind local vars )
   ( main loop )
   #1+_ONE_DO (DO)
      RCL_sum %%+ STO_sum
      RCL_n %%2 %%- STO_n
   LOOP
   RCL_sum %%>%
   ABND
There was a mistake in my reply to Werner which has now been fixed (14 minutes 59 seconds, not 14.59 seconds, which means the two terms at a time version might take about 8 minutes). The HP-42S can never be faster than the HP 50g. Sorry for the confusion!
98.85 seconds on my HP-48GX, and 46.97 seconds on my HP 50g, timed with TEVAL:
%%HP: T(3)A(D)F(,);
\<< TICKS 0 ROT DUP 2
/ 1 SWAP
  START DUP DUP 1 -                         ; on the HP 50g, DUPDUP
* INV ROT + SWAP 2
  NEXT DROP TICKS
ROT - B\->R 8192 /
Gerson.
04-01-2014, 03:54 AM
Post: #76
(04-01-2014 02:57 AM)Gerson W. Barbosa Wrote:  ...(14 minutes 59 seconds, not 14.59 seconds, which means the two terms at a time version might take about 8 minutes). The HP-42S can never be faster than the HP 50g. Sorry for the confusion!
I don't own or have access to a 42s, so I wasn't sure. I will confess, however, that I was a bit suspicious about at 14.59 second timing on a calculator with those specs. Wink Thanks for the clarification.
04-01-2014, 06:50 AM
Post: #77
(03-31-2014 10:13 PM)DavidM Wrote:  Not surprisingly, the SysRPL version was noticeably faster. But still not as good as the 42s/34s versions.
If I understood what you did your User RPL version only uses the stack but your Sys Rpl version uses local variables pretty heavily. I would bet the Sys Rpl version could be tweaked to run a lot faster from the stack.
It ain't OVER 'till it's 2 PICK
04-01-2014, 08:32 AM
Post: #78
(04-01-2014 06:50 AM)HP67 Wrote:  If I understood what you did your User RPL version only uses the stack but your Sys Rpl version uses local variables pretty heavily. I would bet the Sys Rpl version could be tweaked to run a lot faster from the stack.
You might be surprised. Smile
My first attempt at creating the SysRPL version was entirely stack based:
    SysTime
    %%0
    %% 10000
    DUP %%2 %%/>% COERCE
    #1+_ONE_DO (DO)
        DUPDUP %%1 %%- %%* %%1/ ROT %%+
        SWAP %%2 %%-
    LOOP
    DROP %%>%
    SysTime ROT bit- HXS>% % 8192 %/
It was very close to the same speed as the local vars version, but very slightly slower. I'm talking about hundredths of a second when averaged over 5 runs. If I ran them both 20 times, I'm not sure which one would have come out ahead. In the end, the local vars version was easier to read (and follow), so I posted that one.
This may not seem intuitive to some, but the use of null-named locals (as I used in the first SysRPL example I posted) as opposed to named locals (which is what you get with standard UserRPL) is significant. Null-named locals are very efficient; they are accessed via an index into a table instead of being searched out by matching a string. This means that recalling/storing null-named variables is very fast. If you can avoid some stack manipulation steps by using null-named local variables, you're likely to see a time savings as a result. Additionally, your code will be much easier to understand and maintain when you can use locals as opposed to manipulating everything on the stack.
In this case, it's nearly even in terms of time. Both versions are fairly easy to understand. In larger projects, it becomes a no-brainer IMHO. When it's close in performance, code clarity (and thus maintainability) wins.
04-01-2014, 09:17 AM
Post: #79
Thank you for the info. From your description of null-named locals it would seem the stack version should still be faster, all else being equal. I'm surprised over 10,000 iterations it didn't have more impact.
04-01-2014, 07:37 PM
Post: #80
(04-01-2014 09:17 AM)HP67 Wrote:  From your description of null-named locals it would seem the stack version should still be faster, all else being equal. I'm surprised over 10,000 iterations it didn't have more impact.
Looking at the two versions, the stack version of the loop actually has fewer steps. So I also thought that the stack version would be faster when I first coded it. But the most time-consuming operations in the loop are the computations, not the stack manipulations. Moving pointers around is practically inconsequential when compared to the time involved to compute the inverse of an extended real BCD value (or the sum or product, etc.). The most time-hungry parts of the two loops are exactly the same (-,*,1/x,+,-). That's why the timings are so close; the two versions spend the bulk of their time doing essentially the same steps.
To check my sanity, I did some more testing of these two versions. I created another code object which ran both versions (one after the other) in a loop of 20 iterations. On an emulated 50g (Emu48 1.53+), the stack-based version was faster than the local vars version on 18 of 20 iterations. When I ran the exact same test on my real 50g, the local vars version was faster 16 of 20. In both tests, the differences were minor.
To me, that means that the two versions are so close in speed that other idiosyncrasies of the system (intermittent garbage collection, nibble-alignment, interrupt handling, clock irregularities, etc.) are what's making the difference between the two.
