HP Prime CAS & Large numbers
08-10-2017, 08:27 AM
Hi
I've been looking on the internet for answers to this question but can't find anything. When using the CAS for very large numbers for example (256^256)*2^40, how do I convert this to scientific format (exact or otherwise)? I can do it online of course but wondered if I can do it on the calculator. I've tried setting scientific format with say 8 digits but it doesn't do anything and of course if I copy the number to the home screen I just get infinity. Bipman |
08-10-2017, 11:35 AM
RE: HP Prime CAS & Large numbers
Simply type Shift Enter instead of Enter, this provides the result in scientific format.
Hth Arno |
08-10-2017, 11:39 AM
If I try that I get +Inf.
Bipman |
08-10-2017, 12:31 PM
That's because floating-point numbers in Prime's CAS are limited to a maximum of roughly 10^308. Anything greater than that will be returned as infinity.
Examples: 2^1023.9999 --> 1.79756853259e308 2^1024. --> +Inf (notice the decimal point in the input) 2^1024 --> exact 309-digit answer Here's a trick: If your CAS result is too big for CAS to convert to a real, but smaller than 500 digits, you can easily convert it to a real by importing it into Home. Just press Home, Menu (the physical Menu key), Get from CAS, then select the number. Unfortunately, your example, (256^256)*2^40, is too big even for Home to handle (it's 629 digits long). If you want to see how long it is, just use size(string(Ans)). You can also use the following "biglog" program to return the common log of large CAS integers. It works with CAS integers of any size. #cas biglog(d):= BEGIN LOCAL j,k; IF type(d)<>DOM_INT THEN RETURN "Argument not integer" END; d:=abs(d); k:=string(d); j:=expr(head(k)+"."+tail(k)); return size(k)-1+evalf(log10(j),13); END; #end <0|ɸ|0> -Joe- |
08-10-2017, 02:03 PM
Thanks, that's great!
Bipman |
08-12-2017, 06:12 PM
Ooh ooh ooh, here's a nifty way to convert any large CAS integer into floating-point notation:
format(2^7777,"d20") --> "1.2890693393361565650e+2341" Change the "20" in the input to however many significant digits you want. Cool, huh? <0|ɸ|0> -Joe- |
08-13-2017, 09:11 AM
That's cool!
Bipman |
