Display for Voyager / HP-15C
03-07-2017, 09:19 AM
I have a HP-15C with serial no. 2438B Unfortunately the display is damaged and slowly bleeding to death. There was an article on compatible displays from other Voyager models but I cannot find it. Can someone please point me to it (or tell me which calculators are compatible)? Kind regards Andreas |
03-07-2017, 03:39 PM
RE: Display for Voyager / HP-15C
(03-07-2017 09:19 AM)ormembar Wrote: Hello, Any display of a compatible vintage Voyager can be used, so look for a cheap 12C on auction sites. Verify the same vintage/design as yoyr 15C by checking the type of battery contacts; it's more reliable than using serial numbers. The earliest Voyagers had small nearly flat contacts on both sides with clear plastic battery retainers again on both sides. The later ones had a coil spring and clear retainer only on the left side (looking from rear with bat at top). --Bob Prosperi |
03-07-2017, 03:49 PM
(03-07-2017 03:39 PM)rprosperi Wrote: The earliest Voyagers had small nearly flat contacts on both sides with clear plastic battery retainers again on both sides. The later ones had a coil spring and clear retainer only on the left side (looking from rear with bat at top). So that is what I have to look for? - Sounds good - I have a 16C with the same design - or is that a waste? |
03-07-2017, 06:37 PM
RE: Display for Voyager / HP-15C | |||
03-07-2017, 07:09 PM
03-08-2017, 12:45 PM
Definitely a waste!
A lot of us would give our left nut to get our hands on a working 16C ![]() |
03-08-2017, 01:34 PM
Since ebay is full of fictuous prices: What would be a reasonable price for a 12C and a 16C?
03-08-2017, 10:39 PM
03-09-2017, 11:32 AM
I recently paid (like 2 or 3 months ago) 25 € for a working 12C from '88. I was planning on taking it apart and re-use the keys... the PCB is held in place with those plastic retainers.... one way calcs are they
User(s) browsing this thread:
