Question on complex arithmetic with 15c
07-18-2016, 07:19 PM
I read this post
http://www.hpmuseum.org/cgi-sys/cgiwrap/...ead=137175
but don't understand it! :-)
If I type in that program, can someone explain how do I use it for calculating with complex numbers?
(I am calculating electrical impedance so just need to work in two dimensions with the "a + jb" format; I do have a complex number RPN app on my iPhone but it would be handier to grab my 15c on the table and do it).
Thanks!
07-18-2016, 08:51 PM
RE: Question on complex arithmetic with 15c
The 15c handles complex numbers pretty well. Unless you need the fuctions added by that program, you don't need it.
Just set flag 8 and all built in functions are now complex. You can edit real and imaginary part using the re <> im button. The 15c manual is availaböe online from hp an describes all this in detail.
07-19-2016, 03:27 AM
OK thanks. Now that you mention it, it rings a little bell.
Will check the manual.
07-19-2016, 12:14 PM
(07-18-2016 07:19 PM)lemontea Wrote:  I am calculating electrical impedance
Pls post the example here!
Thnx!
Csaba
User(s) browsing this thread:
